Not sure if i need this bolt in the middle or not on the exhaust?
Old 05-07-2009, 04:33 PM
calltrex's Avatar
22RE Header
Not sure if i need this bolt in the middle or not??
When i took the old exh gasket off it was cut in 2 pieces. I put the new gasket on but left it in 1 piece. noticed after that i couldnt put the middle bolt in. Dont think I need it but just making sure..
was only worried if it plugged a coolant hole or something from the stock exhaust?
Last edited by waskillywabbit; 05-07-2009 at 06:12 PM. Reason: Please do not post generic titles per posted sticky
Old 05-07-2009, 04:50 PM
malteserunner's Avatar
You don't need it. I don't have it in mine (Downey header).. Good luck!
Old 05-07-2009, 05:42 PM
corax's Avatar
x2, you'll be fine
Old 05-07-2009, 09:34 PM
iamsuperbleeder's Avatar
yeah, I don't think it's needed, but I once thought that I had an exhaust leak from there; oddly enough, I put a bolt in it, and the leak stopped, but came back within a day turns out the cheap paper gasket that came with the header had broken apart into about 20 peices, lol
Old 05-08-2009, 07:19 AM
Staff
DeathCougar's Avatar
The center hole is there for othe earlier 22R which used just a center exhaust bolt, instead of two in the middle (one on each side) You do not need it.
Blamalam
03-12-2022 07:34 AM
jashoeuh
11-26-2017 07:01 AM
tj884Rdlx
08-28-2015 12:04 PM
accuracy
08-06-2015 12:32 PM
hexrain
07-12-2015 01:13 PM
Quick Reply: Not sure if i need this bolt in the middle or not on the exhaust?
