not sure if i have lockers
Old 03-19-2009, 01:45 PM
xzyragon's Avatar
How do you tell if you have lockers?
Im just wondering cuz i was cruising without a radio on the other day (very rare for me) and i noticed that my tires squeal a lot when I make tight turns. Is this just normal for a 2wd or do I have lockers.
Sorry for no pics, but the camera is chargin atm.
What do you look for?
Old 03-19-2009, 02:07 PM
Dbl. E's Avatar
The easiest way to tell if you have a locker is to jack up the rear tires and spin them. If they both spin in the same direction you have a locker if one goes forward and one goes backward you have an open diff. It's harder to tell if you have a limited slip because this will act as an open diff except when one tire is slipping then it will lock. To see if you have a limited slip you would have to take out the third member and take a peek.
Old 03-19-2009, 02:11 PM
xzyragon's Avatar
ok...
is it hard to spin the tires?
Old 03-19-2009, 02:15 PM
scuba's Avatar
Ummm, Just jack up the rear pumpkin, tranny in neutral, and E brake off, of course with something blocking the FRONT tires. And spin away...
Old 03-19-2009, 02:17 PM
Jay351's Avatar
Easy peasy.
Takes all off 1 min.
Old 03-19-2009, 02:29 PM
okie81's Avatar
Originally Posted by xzyragon
ok...
With a 22re, yes.
With a s/c'd 3.4, no
Old 03-19-2009, 05:13 PM
Matt16's Avatar
You don't have a locker... you'd know if you did. You might have an LSD, but if you did, I would think the previous owner would have told you it was the LSD was better than Cameron Diaz and Uma Thurman together in a bathtub with lots of jelly.
Old 03-19-2009, 05:19 PM
toyota4x4907's Avatar
Originally Posted by Matt16
You don't have a locker... you'd know if you did. You might have an LSD, but if you did, I would think the previous owner would have told you it was the LSD was better than Natalie Portman and Kiera Knightly together in a bathtub with lots of jelly.
There fixed it for ya, free of charge
Old 03-20-2009, 12:06 AM
space-junk's Avatar
You don't have a locker... you'd know if you did. You might have an LSD, but if you did, I would think the previous owner would have told you it was the LSD was better than Scarlett Johansson and Megan Fox together in a bathtub with lots of jelly.
There... fixed it for you both... free, of course...
Old 03-20-2009, 01:16 AM
OMGAWDZZZ! I forgot about Megan Fox!!!!!
How about Megan Fox, Natalie Portman, Anne Hathaway and Carmen Electra?
TheBFA
02-15-2020 06:55 AM
83yotastockR
11
11-10-2015 06:54 AM
Toys4parts
09-26-2015 01:56 PM
toyotasaurus
09-24-2015 03:30 PM
zz_denis
09-06-2015 03:43 PM
Quick Reply: not sure if i have lockers
