not heating up. and a knoick problem - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-05-2010, 03:28 PM   #1 (permalink)
my 89 22 re 4x doesnt heat up to where it should be. the needle moves about 1/4 at the very most up the temp gauge....and I have a fuuuuunny feeling this has something to do with my heater not blowin so warm....and I need that sucker to, Im in boise,id.its a lil cold out.\
where should i be stickin my nose at on this problem? im kinda lost.
also, I pulled my engine codes a while back and got one for a knock sensor... I found the sensor today and the wire is mostly gone. their is wire comin off the sensor to a connector, which both M and F ends are attached, just no lead off the connector. where does the other end of the wire run? im assuming somewhere to the harness?
thanks for any help/insight.
Gnargoyle(208) is offline
Old 01-05-2010, 03:54 PM   #2 (permalink)
Matt90V6SR5's Avatar
On the operating temp of vehicle,have u tried replacing the thermostat?
Matt90V6SR5 is offline
Old 01-05-2010, 04:11 PM   #3 (permalink)
no i havent. its been parked for awhile and I havent even really touched it since. untill sunday. I wrastled up a accelerator cable finally and got it runnin.
and this is where im at now.
Old 01-08-2010, 03:09 PM   #4 (permalink)
Update gnargoyle?
Old 01-08-2010, 07:20 PM   #5 (permalink)
none yet.its been a cold drive to work....been busy with work and school startin back up. makin time in my schedule this weekend to take a crack at it.
any advise?
Old 01-09-2010, 02:43 PM   #6 (permalink)
I had the same problem with mine, engine running cold. So I changed the thermostat earlier today. Usually when thermostats stop working they dont open, and the engine overheats. So this was different.
Because I did not see anything wrong with the old thermostat, I boiled them together on the stove and too my surprise the old one opened way sooner then the new one.
The process of changing the thermostat was about 1 hour.
Advice: be careful not to damage the rubber seal on the rim of the thermostat. You will problably reuse it.
Arcticman is offline
Old 01-09-2010, 02:50 PM   #7 (permalink)
Send a message via AIM to shaeff
Quote:
Huh? It's like a fifty cent item from the dealer. And t-stats from the dealer are inexpensive enough for me to buy there as well. Many parts store t-stats are crap in comparison.
__________________
Code 52 Tech Thread- What is Code 52, how it effects your motor, and how to fix it!
'94 4x4 heatercore replacement writeup with pics
-'94 Toyota 4x4, 22re, siped 31x10.5 BFG M/T's, 5 speed, MC rear bumper, V6 Detroit Tru-Trac rear, '85 SFA sitting in the side yard...
shaeff is offline
Old 01-11-2010, 07:44 PM   #8 (permalink)
i changed the t stat yesterday...i mean actually put one in.The PO didnt have one in. DOH!
it blows warm air but cools a bit at cruising speeds( 65 miles per hour on the freeway), is this normal for older yotas?
also, where does the knock sensor hook up to? I found it, their is a wire and connector coming off of it, but it ends at the connector. and I have no idea where it goes to...
thanks yota gods.
Old 01-11-2010, 07:57 PM   #9 (permalink)
toyota4x4907's Avatar
Send a message via MSN to toyota4x4907
For an older Yota, I would say yes. Yet, in my '93 I would be sweating in a t-shirt cruising at 65mph when it was -40F ........Best heater ever.
Try putting a piece of cardboard in front of the radiator when you go on longer drives. I notice a significant difference at the same temp when I do this. Just dont forget to remove it when it gets warmer!
__________________
'95 4runner|22re|5spd|138K miles|ISR| 2" BL| 31x10.5 | CompuStar Auto-start| two 170mm LightForce|anti-sway bars removed f/r| Warn manual hubs| ADD bypassed|Diff breather extensions| Yakima roof rack| XLPerformance muffler
'88 4runner|22re|5spd|206K miles|Sold
'93 single cab|22re|5spd|150K miles|Sold|
Pro IFS
toyota4x4907 is online now
Old 01-11-2010, 08:08 PM   #10 (permalink)
ahhhh the old bum house cardboard mod. I'll try it out tomorrow. next few days are supposed to be cold.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
