Is this normal??
Is this normal??
I am chasing down a vibration and was wondering if this is normal,the steering rack I guess you call it right in back of the upper control arm there is some movement in it ,is that normal or is that the problem ,can someone go and shake thier steering rack above the UCA and see if it moves Thank you for your time
what I don't get is there's nothing "above" the UCA...
now if it is in fact the pitman arm's ball that you're reffering too, number one, that's kinda in between the UCA and the LCA... number two, if that's what's got movement, it's a one part fix!
I am talking about the steering colunm right before the steering box there is like a little u joint type of thing I was wondering if there is suppose to be any play in it I will take a pic later thanks for any help
Matt16 there is a u joint looking part in back of the mud guard there in the pic that is the area i was wondering if there is suppose to be play
there shouldn't be any play in the steering column. there should be a fiber disc in the bottom joint on the column.
http://personal.utulsa.edu/~nathan-b.../4steering.pdf
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
it's an online copy of a 1993 factory service manual. a lot of it is applicable to other years as well.
i think he is referring to the 'rag joint' in the steering column and, no, there shouldnt be any play in that. www.4crawler.com has some good tech info regarding that item, search it out.
lee
lee
zombie_barbarossa
10-02-2015 10:54 PM
hiluxinargentina
09-30-2015 11:12 PM
charlie_fong
09-27-2015 10:06 PM
