this is a noob question. do you have to prefill a fuel filter when installing.
Old 03-29-2009, 11:00 PM
gary96360's Avatar
i have no idea because i never work on gassers, just diesels.
Old 03-29-2009, 11:02 PM
Elton's Avatar
shouldn't need to
Old 03-29-2009, 11:04 PM
gary96360's Avatar
oh ok. on the diesels, you have to fill the fuel filter or it wont start.
Old 03-29-2009, 11:06 PM
Matt16's Avatar
Nope.
Old 03-29-2009, 11:32 PM
91Toyota's Avatar
nope...done this several of times and I've ran out of gas several of times. lol.
I'm guessing thats a Cummins on your avatar? Always wanted on!
Old 03-30-2009, 05:53 AM
ozziesironmanoffroad's Avatar
i never have... diesels though, yeah. that, and changing the oil, is all i can do on diesels. all i want to do on em anyway... lol.
Old 03-30-2009, 06:01 AM
mattaway's Avatar
prime the filter before you crank the truck over. (turn the key in the on position for a couple seconds, so the fuel will go through the lines and the filter.)
Old 03-30-2009, 06:24 AM
Squeebs's Avatar
No, just install the new one.... and then turn the key on for about 20 seconds to prime it, maybe repeat one more time to be safe, and then fire her up. Mine usually only needs about 20 seconds of priming, though
Old 03-30-2009, 08:54 AM
sb5walker's Avatar
Actually if you want to prime the line, you'll have to jump B+ and FP in the check connector with ignition on - that will bypass the circuit opening relay that powers the pump. The COR doesn't trip until the start signal, so just turning the ignition on doesn't engage the pump.
smthwsn357
12-04-2023 02:08 AM
Eggslinger
06-08-2019 03:32 PM
pyramid
07-30-2015 10:05 AM
ddg71
07-24-2015 01:24 PM
Fundy Rider
07-16-2015 01:35 AM
Quick Reply: this is a noob question. do you have to prefill a fuel filter when installing.
