Non-A/C P/S pump bracket?
Old 06-19-2015, 03:03 AM
deuxdiesel's Avatar
I have a completely non-functioning A/C unit in my '95 4Runner 3.0. I am also replacing the P/S pump at the moment and it looks like the bracket that comes off the A/C condenser also supports the P/S pump. If I remove the A/C system completely (yes, I could just leave it but it clears up the bay if removed), is there a special bracket that non-A/C trucks used to tie the P/S bracket to the lower block, or is it unnecessary? I never use A/C because I have windows and a sunroof in the works.
Old 06-19-2015, 05:37 AM
deuxdiesel's Avatar
I may have found it on Olathe Toyota Parts- it's called a "pump stay" #4445335010, about $30.
Old 06-20-2015, 02:49 PM
shadowbirdie's Avatar
I have the 91 w/o AC straight from the factory
I can't see it clearing up anything $30 worth, whole area remains crowded with P/S hoses and ignition wiring. There's always a hacksaw and grinder with new paint as a solution. My project was replacing a leaky steering gear. And this is the 22RE so might not be helpful, good luck
Attached Thumbnails Non-A/C P/S pump bracket?-100_0003.jpg
shisha1999
08-14-2015 01:33 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
toyoterferdayz
Diesel Swaps
07-27-2015 05:25 PM
Fundy Rider
07-16-2015 01:35 AM
jon.r
07-11-2015 03:34 PM
Quick Reply: Non-A/C P/S pump bracket?
