No water flowing across top of Radiator...Causes/Solutions??? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 11-25-2009, 02:43 PM   #1
stormin94's Avatar
My 4Runner has an overheating problem at slow speeds (under 25MPH). I thought it might be the thermostat that was bad, and pulled it today. I tested it in some boiling water on the stove, and it opens just like it should.
I filled the radiator, and purged the air out of it. I fired it up, let it get to normal operating temperature, and watched it for 10 minutes.
There is no water flowing across the top of the radiator, and if there was, it's not anything noticeable.
I believe this leaves me with the possibility of a plugged radiator, or a bad water pump.
I replaced the headgaskets in June, but had overheating problems before that, and had a bad water temp gauge, which may have led to the HG failure.
These are just a few of the details I can think of, so just ask if you need more. I can probably think of more.
Anyone know what's causing this?
stormin94 is offline   Reply With Quote
Old 11-25-2009, 03:10 PM   #2
abecedarian's Avatar
Do you have the radiator shroud in place?
Have you checked the fan clutch?
How's your water pump?
abecedarian is offline   Reply With Quote
Old 11-25-2009, 06:50 PM   #3
stormin94's Avatar
I do not have a fan shroud
I have an electric fan
Water Pump is questionable at best.
Old 11-25-2009, 07:13 PM   #4
It may be a good time just to swap out your thermostat. They are cheap and it eliminates that as a possibility.
Chutchman is offline   Reply With Quote
Old 11-25-2009, 07:45 PM   #5
have you noticed any loss of water? could it not be a leaky/sucking head gasket again?
oh yeah, I am no mechanic, but do you mean to say, that if you have a vehicle with an electric
fan, they then do not put in fan shrouds? Because with the problems I have seen in the past, even for myself, on a huge engine, with a monster air swirling engine bay, with a 747 sized propeller, I had heat problems, even with a shroud on, it just wasn't sitting perfectly where it should.
rangerruck is offline   Reply With Quote
Old 11-25-2009, 08:55 PM   #6
stormin94's Avatar
My electric fan doesn't have a shroud. I'm thinking it's water flow problems, rather than airflow, since there was no water flowing across the top of the radiator after 10+ minutes of running at normal temp.
And, yes, I do notice a loss of water, but only if it gets hot. So I think it's just coming out of the overflow reservoir.
Old 11-25-2009, 09:05 PM   #7
BigBluePile's Avatar
Either get the radiator flushed or replace the water pump. If both are factory Id just replace them. Also check your raditor hoses. With the motor running, I would think that if the lower hose is hard and the upper was soft then there is a block in the radiator. If both are soft then look at the water pump.
BigBluePile is offline   Reply With Quote
Old 11-25-2009, 09:08 PM   #8
stormin94's Avatar
Quote:
I'm a little skeptical on sticking my hand down through the belts to squeeze the lower hose...
But the top one isn't very hard, but then again, I checked it with the cap off.
Old 11-25-2009, 09:13 PM   #9
BLKNBLU's Avatar
Quote:
He has already checked it and a new one could be bad also. (unlikely but possible) Remove it altogether and repeat the radiator flow watching to rule it out. (then put it back in) You can also drain the rad and flush it bottom to top with the hose to see if it flows relatively freely. Thats certainly not foolproof but it can give you an idea of how well fluids flow through it. My bet is on the water pump. You can flush the block out as well while the t stat is out if you're so inclined or have any suspicion that the engine passages are clogged up. Good luck.
BLKNBLU is offline   Reply With Quote
Old 11-25-2009, 09:23 PM   #10
stormin94's Avatar
Quote:
How do I flush out the engine?
Old 11-25-2009, 09:27 PM   #11
You can't reach up from the bottom? yeah the hose should be soft with cap off! Flow check the raditor yourself or take it in to get checked.
Old 11-25-2009, 09:29 PM   #12
stormin94's Avatar
Didn't think of that...
Yeah, I'm going to check that out on Friday. I'm also going to try flushing the radiator.
Old 11-25-2009, 09:33 PM   #13
Let us know what you find!
Old 11-25-2009, 09:37 PM   #14
BLKNBLU's Avatar
Shoot, the V6 might be trickier. On the 22re, I remove the t stat and bottom hose. Then stick the garden hose into the bottom rad hose and wrap it up with a rag. Eventually, the water flushes all the way up through the engine and flows freely out the t stat hole. I'm not sure but looking at pics of the V6 it looks like you could do essentially the same thing by removing the t stat and top hose. Run the water in the t stat hole until it flows out the hose. Same idea, just that I have t stat/top and hose bottom while you have t stat/bottom and hose top. When I'm done I let all the tap water run out and refill with a coolant/distilled water mix. It's hard to tell from the FSM pics, can you get a clear shot at the t stat housing with the hose or is there stuff in the way?
Old 11-25-2009, 10:27 PM   #15
stormin94's Avatar
I think I could get a hose in there. There's enough room to wrench, so I think I'll be able to get a hose in.
Turbocharging A Stock 22re? RatOmeter 86-95 Trucks & 4Runners 15 10-22-2015 04:17 PM
Couple of specific water pump questions... TJWilly 95.5-2004 Tacomas & 96-2002 4Runners 6 07-31-2015 03:05 PM
No heat jjrbus 86-95 Trucks & 4Runners 5 07-19-2015 03:06 PM
Transmission fluid, direction of flow? jjrbus 86-95 Trucks & 4Runners 1 07-17-2015 08:06 AM
22r Loss of Power and Clicking. cars-guy Pre 84 Trucks 1 07-11-2015 08:51 PM
Tags
4runner, 98, cap, flow, flowing, flowng, hose, minutes, normal, radiator, radiators, running, s10, top, vehicle, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
