no pressure in cooling system when truck is hot
Old 07-02-2009, 07:27 PM
weakyota91's Avatar
Question no pressure in cooling system when truck is hot
Im posting this for a friend trying to get a couple other ideas. 93 3.0 yota new headgasket 2 weeks ago. They went out and drove about 40 miles hauling a bed of hay. truck runs fine nice and strong no overheating no coolant loss but when they return home and pop the radiator cap within a couple minutes of driving theres no presssure underneath the cap at all. its still full and very hot coolant. Doesnt this seem strange? The only thing i can suggest is replace the cap to start with. They havent done anything yet. anyone else had this problem Thanks guys
Old 07-03-2009, 06:48 PM
whokrz's Avatar
Yep the cap would be a good start.
Old 07-03-2009, 07:12 PM
abecedarian's Avatar
agreed- if the cooling system / radiator isn't holding pressure, the first place to check would be the radiator cap. after that... who knows? a cooling system pressure test and checking for leaks then a leak down test may help find the problem.
Old 07-04-2009, 11:33 AM
desertcamper67's Avatar
The water's got to be going somewhere. Internal or external leak. Can you smell coolant?
Old 07-05-2009, 10:34 AM
weakyota91's Avatar
its not loosing any coolant at all its just not building up pressure when it been running for a while. im positive its gotta be the cap thanks guys
Old 07-05-2009, 11:39 AM
Justinlhc's Avatar
I know you keep saying it's not losing coolant, but I'm pretty sure it has to be going someplace. If the cap is what's causing this problem, it's allowing coolant to leak out of the overflow when the pressure rises. Is the overflow container full after driving?
Team420
01-12-2021 04:57 PM
noahstancik
07-10-2015 11:18 AM
rwh2toyota
13
06-27-2015 05:39 PM
Quick Reply: no pressure in cooling system when truck is hot
