No more surging
Old 02-02-2010, 12:39 PM
94toy22re's Avatar
No more surging
I was searching for surging problems for the 22re and a post came up on IH8MUD.
not my pics
http://www.flickr.com/photos/steve-wilson/4169509829/
http://www.flickr.com/photos/steve-w...n/photostream/
I took mine off and cleaned it and the surging has stopped.
Douse anyone know what that valve is called? The coolant hose is connected to the IAC.
Old 02-02-2010, 02:50 PM
Junkers88's Avatar
Hey I wonder if that thing being plugged could be part of the cause for a high cold idle? Might be doing some cleaning this weekend to see if it helps. If water can't flow into the IACV then I'm guessing it might be part of the problem.
Old 02-02-2010, 03:05 PM
kiyobrown's Avatar
And I would think if it didn't flow, it would affect idle like you have probs with junkers. I thought surging was a high idle and the computers response was the loping idle during braking. But if it solves the problem, it solves the problem. Hope it works!
Old 02-02-2010, 03:06 PM
Junkers88's Avatar
Kiyo those links are dead.
I'd love for it to be that little valve thing since my IACV is a pain to remove.
edit: I see you noticed the dead links already.
Old 02-02-2010, 03:27 PM
94toy22re's Avatar
I spent $300 at the local dealer and they couldn't find the problem, and i replaced the maf and iac with no luck and cleaned that little port and it fixed my surging.
Old 02-02-2010, 03:44 PM
Junkers88's Avatar
Man I hear you about spending money and then fixing it yourself. I dropped a large portion of my slush fund at the local place when I had my 86 to find out why it idled so bad and the diagnosis was everything from worn brake shoes to old oil. Turned out to be an intake gasket..... I do my own work now.
I'm glad you found this as I'll try cleaning that little thing and see if my cold idle lowers at all.
Old 02-02-2010, 03:48 PM
kiyobrown's Avatar
Yeah I tried posting them to make it easier for folks to look at it. They denied me.
Let us know that works on your idle.
Old 04-04-2011, 12:12 PM
Junkers88's Avatar
Bringing up an old thread here since I finally pulled that little part to see if it was clogged. Well it wasn't clogged but it's damn sure bent and was cross threaded by whoever took it out before.
Any idea what it's called? I contacted the local parts place and the guy had no idea what I was talking about since I don't know what it's called? I'd like to replace it.
This is the month to fix this freaking idle issue.
Old 04-04-2011, 01:26 PM
94toy22re's Avatar
on the original posting on ih8mud the guy called it a aav port but i don't know if that's correct or not.
Old 04-04-2011, 01:29 PM
Junkers88's Avatar
Thanks!!
Old 04-04-2011, 01:34 PM
94toy22re's Avatar
off topic but going to az this summer and going to go through white sands, i remember seeing some 4x4 only signs is there anything out there worth checking out.
Old 04-04-2011, 01:39 PM
Junkers88's Avatar
Haven't been to White Sands in a long time so I can't give you any good info. If you get into Albuquerque though we can go find a place or two to wheel. I'll even cook you a steak.
Old 04-04-2011, 01:59 PM
94toy22re's Avatar
thanks for the offer. im ready to get out and have some fun i haven't done any wheeling since fall because the closest place to go is a 3hr drive and then all i see is heeps.
Old 04-04-2011, 02:20 PM
Junkers88's Avatar
Ah there are a lot of Jeeps here also although I do see the occasional Toyota (usually up on chrome 20's) in town. We have a couple places to wheel, nothing crazy except for this, which I have NOT tried... yet.
I'm sure we can find something to go mess around on, perhaps some land bureau service trails.
Let me know if you come this way, send me a pm or something and I'll send you my phone number. Heck if you have to stay overnight I've got an apartment that I don't use for you to sleep in.
smthwsn357
12-04-2023 02:08 AM
wafoogalla
11-02-2016 11:02 AM
Ditch Doc
10-27-2015 03:20 PM
Gurr
09-12-2015 09:51 PM
PBRaddict#1
08-22-2015 11:34 PM
Quick Reply: No more surging
