No Luck Tshooting no 4X4
Old 08-30-2007, 05:48 AM
TomThumb's Avatar
Thumbs down No Luck Tshooting no 4X4
Did the basics lick vac and vss switches. Madd Relay is not picking up when you shift into 4x4. Even if the light does not come on the dash shouldn't the Relay click before the vss switches change vac on the actuator?? Running out of ideas and any help would be great.
91 Toyota 22re 5speed with ADD already searched and found basic tshooting steps but still having issues
Old 08-30-2007, 06:53 AM
eric-the-red's Avatar
There is a switch on the transfer case that detects when you shift into 4wd. That switch closes a circuit to ground and switches the output of the ADD relay from the 2wd VSS to the 4wd VSS. If the relay isn't clicking then that switch could be bad.
Old 08-30-2007, 04:58 PM
mr toytech's Avatar
try tapping on the front actuator w/ a hammer when shifting it. with the truck off the ground. have fixed many this way.
Old 08-31-2007, 06:16 AM
TomThumb's Avatar
Thanks guys i will try that this weekend. will keep you posted
mussy01
12-13-2016 08:20 PM
skebe22RTE
07-31-2015 02:03 PM
defrag4
07-31-2015 10:50 AM
PopsDad1
07-30-2015 02:21 PM
pyramid
07-29-2015 06:53 AM
Quick Reply: No Luck Tshooting no 4X4
