no instrument cluster lights, no runnng lights
all my lights work except my gauge lights and running lights.. all fuses are good, bulbs are good
this happened all of a sudden and just stopped working.
they worked fine yesterday, but no pop nothing. the fuses are all good tho? i still have working brake lights and signals. but i dont have running lights out back...
anyone have any ideas, or even where i should start looking? say the dimmer switch is ed...can i bypass it?
LOL
Back to the main Q, did you check the driver's footwell fuses, the dash light/ running light fuse (same fuse) is behind the fusebox in the DS kickpanel. There's a little access hatch that you open and onthe reverse side of the hatch it tells you which fuse is which.
k im working on it right now, i have no tails, i have no radio, i have no gauge lights. plus i dont have running lights, however i do have high and low beams.... 91 yota pickup... i have no blown fuses and all my grounds seem to check out...
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 08:05 AM
Esibnitsud
07-30-2015 08:21 PM
rushw
07-18-2015 01:46 PM
