no idle up when a/c is turned on
Old 04-09-2012, 04:36 AM
fausto's Avatar
I've got a 1993 toyota 4x4wd v6 3.0 and when i turn on the a/c engine does not idle.
Old 04-09-2012, 05:13 AM
blakefogt's Avatar
does it stall?
Old 04-10-2012, 12:02 PM
fausto's Avatar
idle problem
It does not stall. I forgot to mention it is an auto trans, in park when you turn on the a/c the engine does not idle up. Truck runs fine, it has 220,000 miles on it. The guy i bought it from replaced timing belt and trans .
Old 04-10-2012, 12:55 PM
James Woods's Avatar
Are you sure the compressor is kicking on?
Old 04-10-2012, 04:41 PM
fausto's Avatar
idle problem
Yes a/c is working fine, i had a/c company check a/c system when i purchased the truck. Ive herd that there is a idle up valve, but don't know what it looks like or where it is located in the engine bay. And is this unit adjustable?
Old 04-10-2012, 05:03 PM
angrybob's Avatar
Start here and go through the next couple of pics...
http://www.4crawler.com/4x4/CheapTri...ne_Pix/10.html
Old 04-10-2012, 05:18 PM
fausto's Avatar
idle problem
Went through pics, I noticed that the motor is a 4cyl., I'm running a V6, 3.0L motor.
MO transplant
04-23-2023 11:58 AM
Sleaker
08-26-2020 06:03 AM
jackiebrownia
07-20-2015 09:02 AM
luckypig44
07-19-2015 11:25 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: no idle up when a/c is turned on
