No freeway power in fifth
Old 11-25-2008, 08:35 AM
g_mau18's Avatar
Alright here it goes, '88 pickup, 22re, 31x10.50x15, stock gearing, stock height, im not sure, the torsion bar might be cranked but i dont know how to tell. but why do i have absolutely no power on the freeway? 4th gear pulls fine but fifth sucks. should i get a cold air intake to increase hp, or headers? whats a mod i can do to help with power on the highway?
Old 11-25-2008, 09:10 AM
89whitetoyota's Avatar
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
get used to that its a 22re.
Old 11-25-2008, 09:18 AM
Belize Off Road Team's Avatar
There is no power in 5th gear, its basically an overdrive. Regardless of what motor you have, 3VZ-E or 22-RE.
Old 11-25-2008, 09:21 AM
87LVRunner's Avatar
Gears...
Maybe a good tune up with a good new coil...
Tail Wind?
Only drive downhill?
Advance your timing...
Replace engine with bigger one!
Old 11-25-2008, 09:28 AM
highonpottery's Avatar
sounds pretty normal. one thing you can do that really helps is get yourself some good tunes and a frosty cold beverage to keep your mind off gettin' passed all day long. that or re-gear your diffs to 4.56 or 4.88 and get back into the power band.
Old 11-25-2008, 09:36 AM
you want power in 5th? get a 5JZ-GTE or 2JZ-GTE
Old 11-25-2008, 11:38 AM
Keith B.'s Avatar
When you state 'stock gearing', do you mean stock for 225/15 tires or stock for 31/15 tires? If your truck was originally sold with the itty-bitty Ford Falcon tires(as mine was), then with 31's it'll have no poop in 5th. I changed my tires to 31", the gearing to 4.56(from 4.10 stock), and with my recent effort to maximize fuel economy, I've found that it can actually accelerate up a slight hill on the interstate in 5th!
Old 11-25-2008, 11:53 AM
DYNNOMMYTE's Avatar
in the stock form ( gearing and tires ) as it was said..5th is for overdrive and a slug on the highway...
Do a regear, kill the clutch fan and go electric.
A cold air intake will help some...
make some mods and post your results..
Old 11-25-2008, 12:28 PM
laxyoat99's Avatar
its a 4 banger yo and you got some larger tires do the math trucks are stock with about 100hp not a whole lot
Old 11-25-2008, 12:34 PM
99SR5's Avatar
Originally Posted by 87LVRunner
Gears...
Tail Wind?
how would one advance the timing on a 22re?
Old 11-25-2008, 01:45 PM
87LVRunner's Avatar
It's been a little while since I have done this but you have to ground out a plug under the hood, use a timing light, and very slightly turn the distributor. I'd have to check in the shop manual. I've done this on a few trucks and I get a taste more power out of it. You can do it sans timing light, by listening to the truck. I advanced mine a little too far and got some pinging so I retarded it a little, now it's good. I'm running a slight advance, modified intake, 4:88, 33 inch tires, and I can pull hills in 5th. I actually drive around town in 5th gear going 45 and it will still pull.
Old 11-25-2008, 02:17 PM
99SR5's Avatar
yeah i need to do that lol
Old 11-25-2008, 02:47 PM
Jay351's Avatar
Re-gear the diffs to 4.88's The 22re's don't have much power, as stated (112 crank hp or so?). And add to the fact that your truck weighs almost 4,000lbs...
Tune up and re-gear if you got the money (or go to a smaller tire).
Old 11-25-2008, 03:02 PM
g_mau18's Avatar
thanks for the help, its not that bad of a problem im just gunna have to re gear
Old 11-25-2008, 09:28 PM
87LVRunner's Avatar
Guessing you are not agreeing and that's okay. I live around 2100ft above sea level so I advanced my timing slightly. Not saying you would get a crap ton of power out of it, just runs better and pick up is a bit better. I swapped out my exhaust for a system that matched the size of the exhaust manifold so I could keep backpressure up a bit as well. After owning my sixth Toy I know what works for me. Oh and I use 10w40 oil.
smthwsn357
12-04-2023 02:08 AM
themightykhoner
08-11-2015 07:37 PM
Sidherish
08-02-2015 01:42 PM
anniesball
07-30-2015 12:14 PM
redghost.308
California SoCal
07-16-2015 07:46 AM
Quick Reply: No freeway power in fifth
