no fire need help
Old 08-23-2011, 04:17 PM
94dangerranger's Avatar
no fire need help
I have a 1995 4runner 3.0 v6 I did a hg job and when I went to start it I had no fire . The coil and coil igniter are good I had them checked . I bought a remanufactured distributor and I still have no fire so then I checked all the wires leading to the coil and igniter and the distributor and they all have juice going to them. Any sugestions?????
Old 08-24-2011, 12:47 AM
TNRabbit's Avatar
Have you checked the big 80-amp fuse in the fuse block on the passenger side fender under the hood? If blown, don't try to pull it; you have to remove the entire fuse panel from the fender & remove the bolt that holds the fuse in from underneath.
Old 08-24-2011, 07:35 AM
No I haven't but I will try that now
Old 08-24-2011, 01:05 PM
I checked the fuse it seems to be good. I don't know what's wrong with it
Old 08-29-2011, 04:31 PM
I need help guys please reply
Old 08-29-2011, 05:53 PM
Ok guys I have a prob when ever I. Was searching for a ground prob the ground arched so I have a hot touching a ground somewhere has anyone ever had this prob?
Old 09-01-2011, 03:39 PM
I've checked everything I can think off can someone please help me . My 4runner has been down for two months I can't seem to figure it out
Old 09-01-2011, 04:35 PM
TNRabbit's Avatar
Did you do the HG yourself?
Does the 80 amp fuse look like this:
http://pbr251.photobucket.com/albums...g?t=1242034467
That one is burned out.
Did you use the FSM to put the engine back together?
Old 09-06-2011, 05:00 PM
No the fuse looks diff than that one on the inside mine is good. Not to sound stupid but what is fsm
Old 09-06-2011, 05:19 PM
dntsdad's Avatar
Explain this more.
Old 09-08-2011, 09:50 AM
Well I unhooked the ground side of the battery . And when I hooked it back up it arched . I had everything off no doors were open to need energy from the battery , I've worked on this thing going on three months and I have never had these kind of complications on any vehicle . I'm clueless and ready to give up
Old 09-08-2011, 10:09 AM
87 'runner boosted's Avatar
So, just to get this straight (and some clarification may be needed), you are getting power from your coil to the distributor, but now power from the distributor out to your spark plugs??? If thats the case, maybe check your distributor and make sure its in time with the engine?? Give us some more info.
Old 09-08-2011, 11:10 AM
TNRabbit's Avatar
You will always get an arc when you connect either side of the battery to form a circuit.
FSM=Field Service Manual or OEM Toyota Manual. You can download one for a '93 truck/4runner online; google search it.
Old 09-08-2011, 04:50 PM
It was by the book and yes I am not getting any fire form the distributor out. Its all new and all has been tested .
Old 09-08-2011, 05:01 PM
Is the distributor in time though??? Get ur engine to top dead center on #1 cylinder, then make sure your distributor is hitting on #1 cylinder spark plug wire.
Old 09-08-2011, 05:08 PM
Its in time . Even if it wasn't in time it would send out some kind of spark
Old 09-08-2011, 06:31 PM
Broknbonz's Avatar
did you figure out the problem ?
where are you located ? anywhere near Franklin or Murfreesboro ?
Old 09-09-2011, 03:29 PM
I'm in cumberland this thing is on my last nerve I moved it out of the shop and put it in my carport. I dunno what else to do I have done everything I know to do
Old 09-14-2011, 08:14 AM
Guys I give up I'm selling it
Old 09-14-2011, 08:22 AM
Nnnooooo!!!!!
Quick Reply: no fire need help
