no crank, 87 4runner 22re
Old 09-25-2011, 11:52 AM
knobs's Avatar
So my rig just randomly started doin this, I crank it and I get the most minimal or no cranking at all and it makes the ticking noise as if I had a dead battery, replaced starter and starter wire, don't have access to a voltmeter till tomorrow so I can't check voltage at the starter solenoid signal wire, all my grounds seem fin and I've got a 4-00 ground wire off the battery, im totally stumped for time being, any ideas?
Old 09-25-2011, 03:06 PM
RedResistance's Avatar
The positive wire that comes from the relay box under the hood to the battery, check for cracks and corrosion. How new is that starter? Take the solenoid out of it and check the plunger contacts. Just the three screws on the back of it.
Old 09-25-2011, 03:11 PM
knobs's Avatar
Ya that positive wire is pretty tore back, ill check that, thanks
Old 09-25-2011, 03:18 PM
Lucky for me the only Toyota I've ever had this problem on was my Supra. It was that positive wire on mine, and resoldering a new one fixed my issue. Lemmie know if that fixes it.
-Shawn
Old 09-25-2011, 10:37 PM
knobs's Avatar
Ok so I got ahold of a voltmeter, checked everything, the only thing odd I could find was at the solenoid plug on the starter I was getting 3 ohms of resistance, is that too much?
Old 09-26-2011, 09:09 AM
Yes, there should be less than .01ohms. how did you have the ohmmeter hooked up?
Old 09-28-2011, 10:05 AM
knobs's Avatar
i had it between the pos battery terminal and the signal wire, probably wrong but i am totally pullin my hair out over this!
Old 10-01-2011, 01:36 PM
knobs's Avatar
Anyone?
Old 10-01-2011, 05:13 PM
knobs's Avatar
Scratch that, got er dialed, the one ground I didn't check, THE BLOCK GROUND! Duhh, thanks for the input redrisistance
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
redneck17
07-17-2015 07:44 PM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: no crank, 87 4runner 22re
