No compression in 3rd & 4th cyl why? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-15-2009, 05:19 AM   #1 (permalink)
I was throwing a Coolant Temp Sensor signal for a few days and it would occasionally cause the engine to buck a couple times, then the light would go out and it would run fine, except when it did that and I was waiting at a stop light and it would stall out and you could smell lots of gas. I'm guessing the sensor floods the engine with gas when it gets a bad signal and it washed out my 3rd & 4th cylinders? Is that a good guess?
I lost those two cylinders all of sudden and was still able to drive it around 30-40km/hr but it was knocking bad. We took the plugs out and 3&4 were black and the compression test confirmed the cylinders were not getting compression. One mechanic I talked to mentioned that cam could have broke in two.
So, should I get a used engine and drop it in or is there anything I should check on first to see if there is an easier/cheaper repair?
4runnerNB is offline
Old 11-15-2009, 07:56 AM   #2 (permalink)
peapicker's Avatar
my 2 cents. Im a fan of rebuilding what you have. When done you know exactly what is in your engine and what kind of shape the internals are in. when a used engine is bought, its just a guessing game as to how dependable it is.
peapicker is offline
Old 11-15-2009, 11:56 AM   #3 (permalink)
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Cam breaking in two seems rather unlikely. But, you could always pull the valve cover off......pretty easy........and have a look. It's right there on top. I'm assuming 4cylinder?
If the coolant temp sensor goes blah, then yeah......your motor will flood. Seems odd to me that it would only flood on two cylinders, but then I'm no pro. What was the code you were getting exactly? Is it possible you were reading the code wrong?
__________________
Matthew
Context is everything....
Quote:
Originally Posted by abecedarian View Post
freckles, shmeckles... that was your acne reflecting on my pearlescent skin.
Get smacked....join chat!
http://www.yotatech.com/misc.php?do=flashchat
thook is offline
Old 11-15-2009, 01:53 PM   #4 (permalink)
I believe I read the code correctly. I've got an engine coming from a toyota mechanic who says the head is new, gaskets etc. Hopefully he's being honest about the engine. I'll probably rebuild my old engine just to get the experience and keep my 4runner going for years to come.
Old 11-15-2009, 02:05 PM   #5 (permalink)
Murakami's Avatar
pull the valve cover off and have a look and make sure your valves are all in spec.
__________________
93 Pickup, std. cab, 22re, 5 spd., 33x12.5 Mickey Thompsons and 4.88s.
Murakami is offline
Old 11-15-2009, 02:15 PM   #6 (permalink)
thook's Avatar
Quote:
Oh....that was a rather quick decision. Good luck.
__________________
Matthew
thook is offline
Old 11-15-2009, 05:11 PM   #7 (permalink)
So, if I find my valves aren't in check and I adjust them, is that going to get the engine running again on all 4.... what will that tell me if they're out of whack? I'd really like to find an easier solution than swapping out my engine, but I have to find it soon because my runner is my only vehicle on the road at the moment.
Old 11-15-2009, 07:11 PM   #8 (permalink)
dannomite's Avatar
You could have damage to your head gasket between the cylinders. Which would allow compression to leak into the next cylinder over. Just a thought.
__________________
1996 SR5 5speed rear locker.
dannomite is offline
Old 11-15-2009, 09:48 PM   #9 (permalink)
abecedarian's Avatar
1st- find a new mechanic to talk to.
2nd- nice to know you believe you read the code correctly. What was it again?
3rd- no... really... humor us and tell us what the code was...
4th- what were the readings on the compression test? ALL 4 CYLINDERS PLEASE.
5th- adjusting your valves isn't going to help if the cam is broken.
6th- Don't ask for help if all you'll do is waste our time.
__________________
Why do people run the dishwasher and walk the dog?
I would love to go look but I'm too busy sorting my random coin flip collection.
abecedarian is offline
Old 11-16-2009, 12:48 AM   #10 (permalink)
JigsN Rigs's Avatar
^ haha harsh reality.. I'm on 3vze I lost all compression on cylinder 1 and it was knocking real bad.. I'm in the process of dissassembly now
JigsN Rigs is offline
Old 11-16-2009, 02:12 PM   #11 (permalink)
I was getting a code 22, engine coolant temp sensor. I know how to properly check trouble codes, but engine internals are not exactly my area of specialty. I've had just about everything apart and back together on 4runners except engines and trannys. I figured someone might have had the same problem and might be able to tell me what they had to fix. I haven't done a compression test myself, I just might tonight when I go drop off my replacement engine. As far as doing a compression test and checking valves I can't think of anything else I can do to see what went wrong short of tearing the engine down, which I will do eventually so I can have a back up that I might juice up a little.
Old 11-16-2009, 07:53 PM   #12 (permalink)
thook's Avatar
Well, causes for compression loss would be busted rings, busted pistons, blown gasket, dead valves, cracked cylinders.......but, it's knocking.
Any smoke? What color, if any?
I'd pull the valve cover and drain the oil......maybe even drop the pan. See if there's any metal in the oil or even a copper tone to it.
__________________
Matthew
thook is offline
Old 11-17-2009, 12:40 AM   #13 (permalink)
JigsN Rigs's Avatar
Yes but if his.rings are shot he would still be getting a little compression. When you have zero compression it could most likely be a busted rod, hole in ur piston, or a valve that is stuck open. I just got the heads off on my 3vze and found my issue was a busted rod. I'm guessing you might be in the same boat.. Good luck yoda
Tags
302, 4runner, 6th, compression, cylinder, cylinders, fix, fourth, gasket, head, rebuild
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
