No blinkers
Old 07-20-2013, 01:38 PM
banditbuggy145's Avatar
No blinkers
I got a 1995 SR5 pickup 5spd with a 3.0 that needs some help. Today my gauge cluster went out so i fixed that(ended up being a fuse). Now i dont have any blinkers but the hazards work(except the rear drivers side) but the bulb isnt burnt out. I just started with these problems today when i hooked up to a trailer. Starting to think its cursed! Any ideas would be appreciated. Also my windshield wiper switch is either bad or the pump is bad cause that stopped working a few weeks ago. Wondering if it could be the switch in the column? Light switch on column works, horn, cruise, etc.
Old 07-20-2013, 02:38 PM
wyoming9's Avatar
Red face
Have you checked the fuse for the turn signals?? Different then the Hazard lights
Clean the socket of the light not working they corroded as well as new bulbs exposed to the air.
Scotchbrite for the bulbs a fitting brush of the correct size works good for the sockets
Perhaps it blew when you plugged in the trailer lights.
easy to pull the windshield washer tank and test the pump and at the same time test if you get voltage when the switch is closed.
If you don`t have a multimeter good time to invest in one.
Old 07-20-2013, 04:13 PM
Its definitely not something with the socket. Its a brand new light and new bulb. Haven't checked the fuse but I will.
Old 07-20-2013, 09:02 PM
just swapped the fuse and still nothing. I bet i bumped a wire when i was playing with the gauge cluster fuse. Anyone have a wiring diagram or wire color?
Old 07-20-2013, 11:05 PM
RSR
RSR's Avatar
http://personal.utulsa.edu/~nathan-b.../4lighting.pdf
Old 07-21-2013, 08:09 AM
Im willing to bet that the drivers side rear hazard isnt working due to a broken wire, but i cannot for the life of me figure out why i have no blinkers. Even if the lights werent connected, the turn signal switch should still work and the indicators should still flash.
Old 07-21-2013, 10:23 AM
narrowed it down to being a problem with the integration relay. Is this a separate relay or do you have to replace the entire fuse box? Guessing a dealer only part?
Old 07-21-2013, 10:53 AM
Mr.Cheekers's Avatar
I had a problem like this. Pulled my hair out for awhile. It ended up being a wire in trailer wiring pinched and grounding out.
Old 07-21-2013, 02:35 PM
im leaning towards that since i pulled a trailer yesturday. Time to pull the bed i guess...
Old 07-21-2013, 02:37 PM
Did you also have your hazards working but no blinkers? All other lights working?
ghostmoney
01-28-2018 11:42 AM
Scotttekoch
09-28-2015 10:30 PM
89Yota4x4RatTruck
08-23-2015 04:05 AM
bvleonov
08-22-2015 11:39 PM
landes94
08-16-2015 12:20 PM
Quick Reply: No blinkers
