| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
No AC after HG fix?
__________________
Current Toyota -95' 4Runner - 3.0/AT - New HG - Yakima Rack - MT's - Hella's - GPS- Sat Radio - Onboard 120V Former Toyotas - 81' Trekker- 70' FJ40 - 76' FJ40 -72 FJ40 - 85 Hilux (ZERO options) 1st Ultramarathon Countdown: Holiday Lake 50K++ Feb 14, 2009 - 34 Miles - Appomattox County Virginia
#2 (permalink) |
The FSM says there is a ground point on the left side of the radiator...anyone know where that is? I don't see it.
__________________
#3 (permalink) |
any chance you don't have the dual-pressure switch plugged in?
edit- that's under the dash so probably not the problem.
__________________
Insomnia: it's a way of life. Ever notice "tupac" spelled backwards is "caput"? Meet me on Zune. Last edited by abecedarian; 08-30-2008 at 12:02 PM. |
#4 (permalink) |
I'm looking for that guy...where is it?
__________________
#5 (permalink) |
left side of the radiator, when in the driver's seat.
__________________
Insomnia: it's a way of life. Ever notice "tupac" spelled backwards is "caput"? Meet me on Zune. |
#6 (permalink) |
http://www.ncttora.com/fsm/1990-1995...c/componen.pdf
go to page 5 and look for the circle with A13 in it, near the top right of the image, and follow the line down
__________________
#7 (permalink) |
I'm still drawing a blank. I did not unhook anything behind the glove box - nor does anything look out of place. All the fuses there are good.
Can anyone think of something under the hood that would cause these symptoms if not plugged back in?
__________________
#8 (permalink) |
I'm drawing a blank as well. Maybe there's a plug that's not seated properly.
Have you tried triggering the a/c clutch with a jumper from the batt?
__________________
#9 (permalink) |
Yep...kicked right in.
__________________
#10 (permalink) |
--Coolant Temp Sensor - may have an input, on EFI if the engine is overheating, the ECU will not allow the A/C to come on, if it doesn't see the Coolant Temp Sensor it will not turn A/C on at all (may have 1 sensor for the gauge & 1 for the ECU)
also check to see if the A/C relay is clicking or turning on, if it is turning on follow the wire up from the compressor and look for stretched/broken wire (may have pulled on something and caused the problem), give a light tug on the wire going into the connector (if it comes out, that was your problem)
__________________
-Keith- kb3scj '88 4runner SR5 - 3.0 7MGE eng swap - Marlin HD W56 - 4.56 V6 Thirds - '82 Toyota Celica Supra LSD up front - 32"x11.5" BFG AT KO's - NWMP Aux Gas Tank - home fab front and rear bumpers - Hannemann fenders - OME Dakar rear springs w/ Bilstein 5150 reservoir shocks Garage Thread "Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond |
#11 (permalink) |
well... umm... Given that, did the a/c start blowing cold?
If not, I think you need to put a manifold on the A/C system and check the lo and hi side pressures. For some reason, the A/C amplifier is not triggering the compressor. But if it did blow cold, it may be a plug disconnected or not seated properly also.
__________________
Insomnia: it's a way of life. Ever notice "tupac" spelled backwards is "caput"? Meet me on Zune. Last edited by abecedarian; 08-30-2008 at 07:57 PM. |
#12 (permalink) |
I did not find any sensors loose or unplugged. I suppose I'll have to check their wiring next. I think there may be validity with the ECU temp sensor theory.
__________________
#13 (permalink) |
*&#@^%$!!!! Its a leak! I must have dinged the condenser. I suppose I'll have to get a can of that UV dye to be sure. That really sucks.
<end_rant\>
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Should I Fix It? | Kinked | 86-95 Trucks & 4Runners | 14 | 04-04-2008 03:22 PM |
| 3rd Gen SAS(SAC) speedometer fix and 4WD indicator light fix | SteveO | Solid Axle Swaps, All Years | 0 | 11-30-2007 08:06 AM |
| Fix it or not? | Govnor | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 08-07-2007 02:58 PM |
| How to fix this? | gotwake | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 05-30-2007 10:07 PM |
| Getting my Fix | Birdman | 95.5-2004 Tacomas & 96-2002 4Runners | 16 | 04-01-2004 08:06 PM |
