ngk iridium ix plugs
Old 09-27-2009, 09:47 PM
machine23's Avatar
does anybody use these in their 3.0? i wouldnt mind putting expensive plugs in if they actually do what they are supposed to do..
any mileage increase? or performance gain?
Old 09-27-2009, 09:58 PM
93yotaSR5's Avatar
Not that I have heard of. I run regular v-power plugs
Old 09-28-2009, 09:29 AM
machine23's Avatar
bump
bump...
Old 09-28-2009, 09:51 AM
sb5walker's Avatar
I've tried all kinds of fancy expensive plugs and none of them worked as well as the old, cheap factory spec Densos when clean and properly gapped. Denso wires likewise work better than aftermarket.
You will likely not do better than all stock denso on your ignition - it was one of the best engineered aspects of these engines. All the parts were designed to work together and they do, well.
Old 09-28-2009, 10:11 AM
TNRabbit's Avatar
I've used Stock Denso, NGK, Iridium....can't say I noticed ANY difference with any of them. The Iridiums will SUPPOSEDLY last longer. I'll let you know in another 100,000 miles... :-)
Old 09-28-2009, 12:29 PM
24Runna's Avatar
I have NGK TX50 wires, OEM cap and rotor, and NGK G-Powers. Honestly not much difference at all. Even with worn out G-Powers gapped at .040 there was nearly no difference.
Old 09-28-2009, 01:23 PM
totally a bro
Staff
vital22re's Avatar
i ran the irridiums.. dont do it.. they are expensive and my motor ran hotter. Why? because they supposedly generate a hotter spark. heat is a bad thing with the 3.0. especially with the week head gaskets. Not worth the money!
Old 09-29-2009, 02:07 AM
TNRabbit's Avatar
Plugs come in heat ranges and you have to get the proper heat range for your driving/engine. Perhaps you chose the wrong heat range...
the1998sr5
15
07-14-2020 08:35 PM
256mbaker
07-31-2015 06:45 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
msane99
07-17-2015 10:13 AM
nick b
07-11-2015 04:38 AM
Quick Reply: ngk iridium ix plugs
