newbie timing chain replacement
Old 03-28-2009, 08:52 PM
arctictoy's Avatar
Hi all, Im doing the timing chain replacement on my 91 22re. Ive never done it before and I want to make sure I cover all my bases. I got a new oil pump, water pump, all new hoses and belts, gaskets, and chain kit. I've got it all torn apart and ready to go back together tomorrow but Im wondering if there isnt something Im not thinking about that should be replaced while Im in there. Thanks.
Old 03-28-2009, 08:56 PM
874runnersr5's Avatar
You seem to have it done, check your crank to see if i needs a "speedi" sleve, or whatever its called. Other than that, it sounds like you got it, you may also want to drop your oil pan and pick out the chunks of plastic from your old guide.
Old 03-29-2009, 07:46 AM
arctictoy's Avatar
Great, thanks a lot. Im looking forward to getting this thing back together.
Old 03-29-2009, 08:18 AM
Brent7mRunner's Avatar
make sure you put some silicone on that 1 bolt that goes throught the head into the cover otherwise you are going to leak there for sure
Old 03-29-2009, 08:33 AM
sandman608's Avatar
did you get just a new chain or did you get one with new slide rail/guide & tensioner pussher
Old 03-29-2009, 10:08 AM
Probably everything since it was a kit
Old 03-29-2009, 10:25 AM
arctictoy's Avatar
My kit does have a new tensioner
fasterspider
10-06-2015 10:24 AM
Ichneumon
09-27-2015 04:21 PM
Badger62811
06-26-2015 09:26 PM
Taz22R
06-21-2015 04:44 PM
paxanders
06-21-2015 06:29 AM
Quick Reply: newbie timing chain replacement
