Newb question but....
I need to know right away (im gonna but new ones tonight) what gear ratio I have in my 89 V6 4runner 5 speed. I know its either 4.1 or 4.3:1 but is there any way to tell besides looking at the gears or jacking up the truck? because if its 4.1 then I am gonna get the 4.56 gears for it and if its 4.3 then I am gonna get the 4.88 gears for it. Thanks
Andy
Andy
You are correct, in your interpretation. However, I think Toyota must have made a mistake because your axle code should be G294. G292 would be a 2-pinion carrier, but I bet you have a 4-pinion carrier, being that it's what should be behind a V6. I say this with some authority as mine is similarly mismarked. Mine's G292, but I do have the 4-pinion carrier, so it should be G294.
This will be important for buying gears, you'll need to know for sure whether or not it's a 2 or 4-pinion, to order the correct ones.
4.88s are and ideal match for 33s and a 5spd.
even if you are getting 31s or 32s i would get 4.88s to have the lower gearing and if you want to go to larger tires you already have the eprfect gearing
