New wheels
Old 07-24-2008, 06:07 PM
93_22re's Avatar
New wheels
I bought some 16 inch wheels for my truck, they are Mickey Thompson Classic IIs and they are 10 inches wide. Im to broke to do any lifting now, is there a tire that i can fit on my stock 93 pickup that will be wide enough to hold the bead well enough.
Old 07-24-2008, 06:10 PM
Jay351's Avatar
31x11.50 would probibly work. But a 12.50" wide tire would work best, but I dont think you could clear it..
Alex 400's Avatar
I doubt it without some trimming. i mean a 11.5 at the max might have a 10" wide rim, but you would want at least 12.5 inch wide tire, which will rub and you would need to trim. good luck. someone else would know more that I though.
Old 07-25-2008, 07:06 AM
76ANTHONY's Avatar
16x10, but the all most important question isssssssssssssss? WHAT BACKSPACE??????
this is theeee most important question.
Old 07-25-2008, 07:51 AM
FredTJ's Avatar
Why did you get 10's instead of 8's ?
12.50's would be the best, however as already mentioned, they'll most likely rub, depending on the BS of the wheels.
8's are best for wheeling anyway. They'll hold a bead a ton better, when the tires are aired down, then the 10's will.
I've even run 12.50's on 7's before and they worked great.
Fred
kouki420
09-02-2015 11:42 AM
NCRidgeRunner
08-13-2015 04:11 AM
Up&Down
08-05-2015 06:20 AM
Luvmeye22re
08-04-2015 03:53 PM
skoti89
07-06-2015 07:45 PM
Quick Reply: New wheels
