New truck clutch change tips an advice
Hey guys first post on here I bought a 1994 4runner 3.0 v6 5speed 4x4 it needs a new clutch. Has brand new master and slave cylinder with no air in the lines so it must be the clutch. Need advice on what brand to get ac delco has a life warranty on it and is half the price of exedy and it only has 3 month warranty. Also while I'm down there what about gear oil for the trans diff, and rear end? Thanks guys. First toyota and I love it so far
Welcome !!
Most would say to go With the Aisin Clutch kit .
I think Marlin Crawlers clutch kit would be my choice
Just what makes you think it is the clutch Slipping ?? Will not Shift into gear without grinding??
Gear oil sae 75w90 This is what is called for but it is a personal choice
I used 85W140 for years
Always remove the fill plugs first
Welcome !!
No. The rear main is accessed from the back of the engine. You just need to remove the flywheel to get to it. Since you'll already have it off to get resurfaced/replaced it's the perfect time since it's a lot to do again if it starts leaking down the road.
Awesome sounds good man I appreciate it guys I'll make a post with pics of the truck if you guys wanna check it out thanks again!!
mbomberz1
72
07-04-2017 12:20 AM
Terofpa
All Other Toyota Swaps
7
09-17-2016 04:48 PM
chicago60647
05-09-2016 11:59 PM
