New Tranny + tcase stuck on 4wd
Old 07-09-2012, 03:02 PM
BlindfoldMemphis's Avatar
I have an 88 4runner that I swapped the original transmission and transfer case out for a set that a guy told me were from 1993. The thing about this new tcase is that it has an extra little thing attached to the back that my old tcase did not. it has some wires that are just hanging out the back that have nothing to to got and now i cannot disengage 4wd.. I have manual hubs so I've been driving around like that. I fell like the case does not have the regular shift pattern, how do i disengage?
I could get pictures if necessary. Thanks for your help.
Old 07-09-2012, 03:11 PM
runs-on-4's Avatar
auto or manual trans?
88 is a top shift style 93 is a forward shift.
Old 07-09-2012, 03:15 PM
runs-on-4's Avatar
and are these wires coming out of the back of the transmission or transfercase?
Old 07-09-2012, 03:31 PM
Manual 3.0
The wires are coming out of the tcase
There seems to be a little plug on what probably is vacuum activated.. my old one did not have that.
Old 07-09-2012, 04:44 PM
runs-on-4's Avatar
when i look at mine i just have the speedo cable. out the back and 4wd indicator
try and jack your truck up so the tires are off the ground, and then it my free up. if not probably a bad tcase .. good excuse to go to dual cases
Old 07-10-2012, 11:25 AM
swampfox's Avatar
I am not sure if you can miss the shift rail with the shifter on that model, but it could be in the wrong place.
mskalmus
05-28-2017 07:51 AM
Tonetrk
08-03-2015 08:47 PM
ripp96
07-31-2015 11:14 AM
yourrealdad
07-29-2015 11:08 AM
shadowbirdie
07-21-2015 10:38 PM
Quick Reply: New Tranny + tcase stuck on 4wd
