new seals for bearings (what are they called)
Old 03-25-2008, 11:39 AM
simpsons721's Avatar
Cool new seals for bearings (what are they called)
when i ask for new seals for my hub what do i ask for at the auto shop
Old 03-25-2008, 11:47 AM
mr_schuster's Avatar
Inner hub seals or grease seals.
Old 03-25-2008, 03:33 PM
Cyberman's Avatar
Sry to jack the thread, but how do you get those seals out?
Old 03-25-2008, 03:35 PM
jason191918's Avatar
With a seal puller/screwdriver/pliers. Do you have the hub off?
Old 03-25-2008, 07:19 PM
Cyberman's Avatar
Both hubs are off. I was going to repack all the bearings, but the seals are in my way. Does that entire metal (brass?) ring come off?
Old 03-25-2008, 07:42 PM
I don't remember any brass....
With the hub off, the outer bearing should just fall out. Look towards the inside and you should see the inner bearing. The only thing holding that on at this point is the seal itself. It should have a rubber inner piece attached to a metal middle piece, attached to a rubber outer piece (aka the seal). Just pop that off. A seal puller works best, but a needle nose/screw driver will work in this case.
Old 03-25-2008, 09:44 PM
Cyberman's Avatar
...It should have a rubber inner piece attached to a metal middle piece, attached to a rubber outer piece (aka the seal).
Ya, the metal piece was what I was referring to. With it in place, it's hard to tell that there is rubber on the outside too.
Thanks.
Old 03-26-2008, 03:11 AM
Oh, OK. Just as long as you don't score the race or damage the bearing it's all good.
jasonty
41
12-23-2018 01:00 PM
4x4-runner
12-27-2016 01:58 PM
Iceman4193
08-28-2015 08:43 PM
calderp
07-27-2015 09:58 AM
Iceman4193
07-15-2015 04:48 PM
Quick Reply: new seals for bearings (what are they called)
