New radio install issue
Old 11-29-2007, 01:07 PM
mtrdrms's Avatar
Well just had a buddy put in a new radio in my 90 pu and now the presets and clock reset whenver I shut the truck off. What did he do wrong? Neither of us can figure it out?
Old 11-29-2007, 01:48 PM
jason191918's Avatar
There should be two power wires for the radio and one ground. One power wire is for "full time" power, and the other one is for switched or ignition power. The switched or ignition power is only hot when the ignition is on, so your battery doesn't die, this is why you cannot turn the radio on when the key is off. The "full time" power lead is for keeping your clock and presets stored. It appears that you either did not hook this wire up, or you just put both leads to a switched/ignition power source. Because of this, whenever you turn off the key, ALL power is cut off to the radio and it forgets everything.
Hope this makes sense.
Old 11-29-2007, 01:55 PM
Spence1016's Avatar
x2
Spencer
Old 11-29-2007, 02:23 PM
Djlarroc's Avatar
x3... and in most cases, not all, but most. The constant power wire is yellow and the switched power wire is red. Best way to ck it though is with a current tester to make sure. Too bad you have a second gen, it is a huge PITA to get to the stereo again.
Old 11-29-2007, 02:24 PM
mikes19984x4's Avatar
haha, can i hear a x4! but yeah, just get the good ole volt-ohm meter out and do a little testing...
Old 11-29-2007, 08:35 PM
NaeSLaS's Avatar
X5, most aftermarket stereos use yellow for permanent power (clock/preset save) and red for switched power.
bigjstang
08-25-2021 12:41 AM
jasonty
41
12-23-2018 01:00 PM
raptor510
02-17-2017 07:11 AM
mtb_taco
07-15-2015 08:36 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: New radio install issue
