new PS pump, really tight steering
Well, we replaced the pitman arm, lower ball joints, and the power steering pump on my 1993. The old PS pump was leaking from the shaft (we believe, thats the only thing left to leak) Now, its decently harder to turn, but its almost sticky, very annoying on the highway, doing little corrections. I think it might be getting better, maybe just breaking in the new pump. I was confused with the two vacuum lines coming out, I think that they are on right. Would that impact the steering? I haven't been able to find anything about this anywhere else.
The two large vacuum hoses off the p/s pump from the intake can be switched around or even removed and capped off with no consequences. They feed into the top of the same valve so your problem has to be somewhere else.
Well, before all that I'd remove the p/s belt and just drive it a little without power steer. It should feel really hard to turn at very slow speeds, but easy above say 20mph. Do some not-too-slow tight turns in a big parking lot and lane changes at speed. If it feels fine under those conditions, then you know it's the pump for sure. Also, does the atf (you are using dexron iii, right?) have bubbles in it while the engine is running?
Another, more expensive, thought popped into my head. We had to beat on the gear from the steering box to get the old pitman arm out, is there a possibility we broke the gear out of the worm drive?
Hammering on parts when a suitable puller is whats needed, is always bad news.
This may turn out to be an expensive lesson.
Hopefully, the box is not damaged.
It is never a mistake to spend money on tools.
I try to buy first quality used tools at pawn shops and such.
A first quality used tool will always be saleable for near what you paid for it.
Chinese slave labor tools are worthless the minute you have laid down your money.
As for the steering being sticky and the new info about bashing off the old arm... yikes! Something sounds broken, and it's not your p/s pump. If you don't know where to start looking, I'd jack up the front and use a stethoscope to find weird noises while someone turns the wheel.
You really should consider flushing the system to dexron iii after you fix whatever's broken (hopefully not the gearbox but don't get your hopes too high). I know some people run p/s fluid with no problems, but it's not the correct stuff to use. I think it's thinner and has a different amount of detergent. You can read threads where people are surprised at how much smoother the system felt after switching back to atf. It's your truck, but just sayin'...
wellssllew
09-02-2016 07:49 AM
Mass03
08-27-2016 02:35 PM
Mikenkesh07
08-23-2016 10:47 PM
NolaToyota
08-20-2016 11:36 AM
