New Master and Slave Cylinder...Bealry any Pedal, cant get into any gear.
Old 02-22-2009, 01:23 PM
89whitetoyota's Avatar
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
I have been pumping the hell out of the pedal and i get a half a$$ pedal that will let me go into gear when the truck is off, but when on wont go into gear. how long should it take the new parts to be rid of air? Also does the rod going through the firse wall to the pedal need any type of adjustment to make the pedal work?
Old 02-22-2009, 01:26 PM
91Toyota's Avatar
Did you bleed the system? I just installed both and mine is really really soft but goes into and out of gears just fine
Old 02-22-2009, 01:41 PM
the system was completely drained we bled it like the toyota manual said, and still wont go into gear.
Then pumped the hell out of it till we got some pedal, pumped it like 10 times held and bled, over and over.
Old 02-22-2009, 02:32 PM
jason191918's Avatar
Can you see the slave cylinder piston go out when the pedal is depressed?
Old 02-22-2009, 04:34 PM
turner01's Avatar
There is an adjustment bolt on your clutch pedal in side the cab. I had to adjust mine when I put new master and slave cylinder in.
Old 02-22-2009, 04:54 PM
The plunger on the slave does move in and out as in moving the clutch fork. I am thinking I have a pressure plate issue. We finally got all of the air out of the lines, but I still dont have enough pressure to get the truck into any gear when the truck is on. If I put the truck in first or reverse, and start it like normal, it starts wanting to move, even with the pedal fully engaged. I guess I have to do a new clutch kit who hoo!!!!
Old 02-22-2009, 05:24 PM
totally a bro
Staff
vital22re's Avatar
have someone push on the clutch pedal and hold. Crawl underneath and see if you can get it to move anymore by hand. to me it sound like you have somthing going on with the master and slave, air bubble, adjustment. dont' think its fully depressing the fork. What fluid are you running in the clutch system? i run dot 4, higher temp rating.
Old 02-23-2009, 10:23 AM
regularjoe's Avatar
I had the same problem when I put my master on. I had to adjust the pedal out a good bit more than the stock one before I got some pressure.
Old 02-23-2009, 05:48 PM
mrguppy's Avatar
had to do the same to my truck
Old 02-23-2009, 08:54 PM
chris1rb's Avatar
wow i just did this to my truck 2 days ago had to replace the slave then found out it was the master so replaced both. i really had to bleed the lines through 3 cycles to get all the air out and now its working perfect, Knock on wood! make sure u bleed them well cause the clutch will act like its working but once u hold the clutch in for some time and the air compresses the clutch will retract and u r stuck in gear almost rear ended someone at a red light last week because of this, hope you figure it out
Old 02-23-2009, 09:59 PM
Skoalbandit's Avatar
Also, I have heard that a lot of old timers will bleed this particular style clutch by simply filling the resevior, cracking the bleeder and just letting it slowly work its way down. Just letting it sit, and letting the fluid work the air out on its own. It will take time, but it's a pretty good method.
kawazx636
10-06-2021 03:03 PM
punks_is_4x4
02-26-2016 04:29 PM
zanzabar0
10-11-2015 02:56 AM
shredder4286
10-01-2015 01:09 PM
Rickstwowheels
09-29-2015 02:23 PM
Quick Reply: New Master and Slave Cylinder...Bealry any Pedal, cant get into any gear.
