New to lockrite
Old 08-06-2009, 11:46 AM
Dipstik_90's Avatar
New to lockrite
I just installed a lockrite in the back of my truck and I don't know how it's suppose to feel. It clucked pretty good going straight once but it hasn't done it since. Also I notice alot of backlash in the diff now but when I set it up there was only 5.5 thou backlash in the gears, m buddy said it was play between the axle and the carrier side plates.
Old 08-06-2009, 11:51 AM
904_runner's Avatar
search mat16's aussie locker writeup. Its teh same style locker and handles the same. he does a good job explaining it, but it does have some quirks.
Old 08-06-2009, 11:54 AM
OutlawMike's Avatar
I have only been driving mine for two weeks.
Coasting through turns is "freewheels" back there, making a thunking sound, deeper than a tick. If I give it some throttle, chirp!! If I really get on it, drag, chirp, bark, etc, etc. This is all in turns.
I did notice that the auto trans thunks into drive a bit louder with the new diff. Part of that might be the 5.29's, but not sure.
I did not set mine up, it came in the used diff.
Mike
Old 08-06-2009, 11:58 AM
Dipstik_90's Avatar
Mine came in a used diff as well but I swapped the ring gear so i set the backlash again. Just the thunk going straight concerned me.
Old 08-06-2009, 12:08 PM
904_runner's Avatar
the lockers will "unload" and CLUNK very loudly almost to the point where it sounded like you broke something
but shouldn't happen all the time.
Mine does it rarely.
Old 08-06-2009, 12:14 PM
scuba's Avatar
x2 same here..
Maybe twice a month...
Old 08-06-2009, 12:28 PM
Dipstik_90's Avatar
Yeah it only did it once so far, it just concerned me because I was going straight. Would having one brand new and one 1/2 worn tire make it do that?
Old 08-06-2009, 12:32 PM
Lumpy's Avatar
Well that is not helping your situation at all...It's bad enough having different sized tires on the front and rear but you definitely should have the same size, worn the same, tires on the same axle.
Old 08-06-2009, 01:48 PM
OutlawMike's Avatar
Yes, definitely that could cause an issue. The RPM's of the axle shafts side to side are "wanting" to be differnet even in a straight line.
Old 08-06-2009, 07:17 PM
Matt16's Avatar
My Aussie has done that once or twice going straight. Its usually when I slow down then get back on the gas. Wouldn't worry about it.
Old 08-08-2009, 11:30 AM
Dipstik_90's Avatar
So any input on the clunk when accelerating? It's like too much backlash but it's not the gears. Are the side plates worn out where the axles go in?
Old 08-08-2009, 12:31 PM
Jay351's Avatar
There will be more play in the diff with the locker. But its not that bad...
Old 08-08-2009, 12:35 PM
Fink's Avatar
Did you do research on the Lockrite before buying it?
This is a very common side-effect of it.
Read Matt's thread about it.
You need to make sure all your tires are the same size and close to the same wear on each of them.
As said before, the different RPM's can cause problems.
Fink
Old 08-08-2009, 04:28 PM
Matt16's Avatar
The only thing you can do to tame the noise is use thicker gear oil. I use 85W140 GL5 IIRC. You can't tame the backlash except by altering your driving.
vasinvictor
01-20-2016 12:39 PM
pillguy
12-04-2008 04:09 PM
Discipher
05-26-2008 11:00 AM
bry-an
03-03-2008 07:39 AM
woody69
02-07-2008 06:15 AM
Quick Reply: New to lockrite
