new issue i came across
Old 11-11-2009, 05:58 AM
jtcessna's Avatar
my truck has only done this once or twice before, now yesterday my truck was bucking and stalling, and hardly wouldnt go, my grandpa suggested its my electrical system, it acts like it is super sluggish in first, and my truck in neutral will skip and hope and almost if not cut off. anyone have any advise as to what i should start eliminating as the problem? thanks
Old 11-11-2009, 06:39 AM
muddpigg's Avatar
Year, moter, tranny, what you/it was doing when problems started, are useful information to those you are trying to get to help you.
Think Gpa might be on to something but I'm guessing more like a sensor like TPS. But could be vacuum line, short, bad plug wires or rotor. To name a few guesses with limited information you gave.
Old 11-11-2009, 06:42 AM
nv4runner's Avatar
Could be your ignitor/coil, TPS, loose connector on any number of things, bad fuel and so on. I'd start by making sure you have spark, then test your TPS. Are there any conditions that it happens under? Only after idling for a while? Only under power? Cruising speed?
Old 11-11-2009, 06:44 AM
gilby4runner's Avatar
crap in the fuel filter?
Old 11-11-2009, 07:22 AM
abecedarian's Avatar
loose grounds?
Old 11-12-2009, 06:23 PM
jtcessna's Avatar
its a 88 yota, and i just replaced my rotor button, dis cap, and all spark plugs and wires. and all hoses
Old 11-12-2009, 06:25 PM
jtcessna's Avatar
it just started and my truck feels like it wont even go, im goin to check my plugs to see if im gettn a spark first and my dis cap, then ill check my fuel filter again.
Old 11-12-2009, 06:44 PM
93_22re's Avatar
x2 on the fuel filter.. and you said all new hoses so i would double check that all hoses are hooked up correct.. just one hose off can let moisture get in the intake.. i doubt it would cause it to stall but you never can tell
bigjstang
08-25-2021 12:41 AM
nvdesertrunner
05-11-2020 08:18 PM
crammit442
7
11-29-2017 12:30 PM
raptor510
08-19-2015 02:15 PM
rjtrials
08-06-2015 07:25 PM
Quick Reply: new issue i came across
