New HG installed. Yotatech Rocks!
Old 12-08-2012, 01:18 PM
LITLRED's Avatar
Still have work to do like but she fired up on the first try.
Old 12-08-2012, 02:12 PM
hgill's Avatar
congratulations! which engine? 22re or 3vz! It definitely feels amazing when you get it running on first try!
Good Luck! Hopefully there arent any leaks or surprises!
Old 12-08-2012, 10:21 PM
LITLRED's Avatar
22RE
2 leaks so far but both were easy fixes. One coolant and one exhaust.
Old 12-09-2012, 03:14 AM
92 TOY's Avatar
congrats. now lets see some pics
Old 12-10-2012, 10:58 AM
hgill's Avatar
Just curious as to how you determine an exhaust leak? is it something obvious like smoke coming out or is there some test.
Old 12-10-2012, 11:38 AM
Philbert's Avatar
+1 for pics! And the exhaust leak finding method...I think I have one too
HGill - any luck on your idle issues after your HG job?
Old 12-10-2012, 04:12 PM
92 TOY's Avatar
for me it was an obvious noise and some condensation coming out where it usually did not come from.
Old 12-11-2012, 12:50 AM
LITLRED's Avatar
It was leaking at the connection between the manifold and Y pipe. One of the round gaskets weren't seated properly. It was a big leak and pretty loud.
I've had a leak there before so it was suspect. When I fired it up the second time I just put my hand down there and could feel the hot exhaust coming out.
Here's some pics.
Napa Exhaust gas test
Spark plugs
Before cleaning
After cleaning
After Deglazing cyllinders
Old 12-11-2012, 01:00 AM
LITLRED's Avatar
I'll share this in case anyone else may have had the same problem.
The first time I had an exhaust leak where the Y pipe bolts to the Exhaust Manifold it was because the pipes that pipes that extend thru the flange on the Y pipe were almost 3/16 in, in spots where the gaskets are maybe 1/8 in thick so no matter how tight I got it it still leaked. I solved it by doubling up on the gaskets.
This time around I ground down the pipe to maybe 1/16 inch proud of the flange. Enough to position the gaskets but still allow them to seal.
the1998sr5
15
07-14-2020 08:35 PM
raptor510
02-17-2017 07:11 AM
Yota.Jay
10-24-2015 08:41 AM
akaphilly
07-09-2015 02:34 PM
Quick Reply: New HG installed. Yotatech Rocks!
