New guages in dash, guess what I have found.
Old 07-23-2011, 08:24 AM
Mikel1871's Avatar
First I found a 12-13 mm box wrench the PO had "Lost in the engine", but that not what I am needing help with.
Lets start off with the new guages(Temp and oil PSI)
Ok so i got my guages mounted in the dash (not a pod man) but when I went to hook up the Water Temp I found that there are 5 sensors where the book tells me the dash guage sensor is, just not which one it is.
Then to beat it all I pulled the upper intake off(this is when I found the wrench) and have come to find a Vacuum line that is not hooked up nor can I find where it may go(comes from the "R" port on the throttle body) and dead ends by the 5 sensors.
Thanks for any info on this as i am stumped, i have to goto the parts place for some new hose and clamps to replace some wore units and will check back in a bit, again thanks in advance for any help.
Old 07-23-2011, 08:38 AM
93toyrunner2's Avatar
A = Dash temperature sender
B = Vacuum valve with two ports - one goes to the vacuum line in the throttle body area, using a piece of vacuum hose to connect to the pipe you have marked in the image above, and the other port (using just vacuum hose) goes to your black vapor canister, passenger side near the firewall.
Old 07-23-2011, 08:40 AM
S.Skinner's Avatar
in the last pic. the busted sensor should look like an F and the vacume line goes on the F.
Old 07-23-2011, 08:44 AM
S.Skinner's Avatar
Old 07-23-2011, 08:50 AM
Thanks for the actual pic Skinner-
A = Temperature sender
B = Two port vacuum valve
C = Goes to the pipe you noted above, using vacuum hose.
D = Goes to the black vapor canister using vacuum line.
Old 07-23-2011, 08:52 AM
Mikel1871's Avatar
So it hooks to the Purge line on the canister then?
Old 07-23-2011, 08:53 AM
Yes it does.
Old 07-23-2011, 08:56 AM
Mikel1871's Avatar
So I can remove the stock temp sender and replace it with the aftermarket one without problems ?
Sweet thanks for the details guys im off once again for parts..
Awsome picture it helped alot.
S.Skinner's Avatar
Glad to be of help for once
Old 07-23-2011, 10:03 AM
Mikel1871's Avatar
B = Two port vacuum valve( this part was a no-go, you wouldnt know what it is discribed as ? or a engine diagram I could view to get a part number from)
Got all my hoses and clamps but not the vacuum port. You wouldnt know of a engine diagram i could view for it?
Old 07-23-2011, 02:32 PM
https://179websites.com/evap.pdf
This is from the FSM
This is from another post on this site:
Originally Posted by thook
There's actually an easy and even inexpensive way to just repair it. And here it is!
https://www.yotatech.com/forums/f116...ix-pics-84460/
'Nother thread....
https://www.yotatech.com/forums/f116...removal-87623/
jasonty
41
12-23-2018 01:00 PM
Marsheen
02-17-2016 12:29 PM
Ktm526
10-07-2015 05:14 AM
Gone Fission
09-04-2015 12:18 PM
izzmee
08-17-2015 10:20 AM
Quick Reply: New guages in dash, guess what I have found.
