new Gauge HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 10-29-2007, 10:06 AM
Belize Off Road Team's Avatar
Exclamation new Gauge HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
while installing my new reverse halo gauges on my 91 Surf, i ran into a issue. while placing the new speedo over the old, the needle popped off! so i called parkcity TOYOTA in Medicine Hat AB Canada, and they said it should not be a problem, so i put the needle back on and now it goes a LOT lower than just below 0 where it should be, it nw hangs out of the frame of the speedo, what the H E L * do i do now? PLEASE tell me i dont have to order new cluster! please if you have encounterd this problem, pm me with a solution.
Old 10-29-2007, 10:12 AM
Old 10-29-2007, 10:29 AM
needsomecam's Avatar
take the needle off, put the truck in gear and while stopped with your foot on the brake put the needle on so it points to zero.
Old 10-29-2007, 03:11 PM
run4her's Avatar
i got my friend to drive 30 and i matched his speed then put the needle back on and my speedo is right on.
Old 10-29-2007, 03:15 PM
OSU4Runner's Avatar
x2....might take a few times to get it right
Old 10-29-2007, 06:45 PM
slosurfer's Avatar
you didn't bust off the stop post did you?
Old 10-30-2007, 01:37 PM
no, i got it now, i just did what run4her did, its good now.
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
zanzabar0
10-11-2015 02:56 AM
Jdgarrison
10-01-2015 05:22 PM
dbollier123
09-29-2015 05:23 PM
Quick Reply: new Gauge HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
