New Distributor, plugs won't fit
Old 01-22-2015, 05:38 AM
Tin Soldier's Avatar
The mechanic that rebuilt my 22re put in a new distributor that has larger diameter plug receptacles than the original Toyota one. I wanted to reuse the wires, but they don't fit. When I look for distributor wire sets for Toyota, they all have the Toyota-specific posts (smaller diameter with little locking covers). Should I reuse the old dist cap or should I look for a wire set that fits the newer, non Toyota dist cap?
Thanks
Old 01-22-2015, 07:59 AM
bswarm's Avatar
There's at least 3 different plug wire sizes, 6mm, 7mm, and 8mm. There are other sizes but I don't think you'll run into them on a Toy. If you go back to your old cap make sure it fits the distributor. The rotor may also be different so compare the parts and make sure you use the one that goes with the cap.
Old 01-22-2015, 02:36 PM
Odin's Avatar
All of those came stock on different 22r, r-e engines? What came with 8mm wires? Wouldn't mind changing to that cap and wires when the time comes.
Old 01-22-2015, 03:09 PM
bswarm's Avatar
I haven't actually seen 8mm on Toys, Yet. I'm sure somebody probably makes caps with 8mm lugs for racing, but it really isn't needed if you get a good set of wires. I tried a set of metal core wires on my mustang, didn't make any difference except for a lot of radio noise.
Old 01-22-2015, 03:24 PM
So would you recommend swapping out the wires to the larger lugged wires? If so, are they available for the 22re without a huge expense?
Thanks
Old 01-22-2015, 03:39 PM
bswarm's Avatar
I'm seeing 2 different sets of plug wires for a 22RE...
1978-1992 http://www.lceperformance.com/NGK-Sp...-p/1083032.htm
Or
1993-1995 http://www.lceperformance.com/NGK-7m...-p/1083040.htm
So pick the one that looks like what you need and get some for that year. I don't know if the cap & rotor are interchangeable for that distributor.
Old 01-22-2015, 03:41 PM
Odin's Avatar
Nothing wrong with the OEM's in a stock application.
I have 8 unused Taylors I was thinking about cutting down for my 22r-e when the time came.
Old 01-22-2015, 03:49 PM
bswarm's Avatar
I have a 8 unused Taylors I was thinking about cutting down for my 22r-e when the time came.
Check http://www.lceperformance.com/ every Toy performance parts you could possibly think of. That 22RE supercharger looks interesting.
Old 01-22-2015, 05:35 PM
Odin's Avatar
That would be cool but I don't want to deviate from stock very much. I intend to keep this a pretty stock 2wd daily driver.
Old 01-23-2015, 05:42 AM
I'm with Odin, yes LCE parts would be awesome but I'm running out of cash and I gotta put my kids through college next year. I had to back down on a $900 purchase of a header and full exhaust kit from LCE with a year end discount. They were great on customer service, but I couldn't get myself to spend that kind of money. I'm planning a total kick ass rebuild of 22re and similar age truck as this one when I retire and I'm going with everything from LCE and 22RE Performance.
For now, I used the old dist wires and cap and they fit snug and have no breaks or problems.
Old 01-23-2015, 09:09 AM
Odin's Avatar
Since you installed a new distributor you might want to clean the metal parts of the old cap with some #0000 steel wool and do a resistance test on those wires.
Old 01-23-2015, 12:13 PM
Yes, good idea. Thanks
sandyota
02-04-2021 11:16 AM
Eggslinger
06-08-2019 03:32 PM
msane99
07-11-2015 08:08 PM
smiley52
07-11-2015 05:16 AM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: New Distributor, plugs won't fit
