New Clutch & Burning smell - help
Old 06-28-2009, 06:39 PM
cchinny's Avatar
Did my first clutch job on my 89 22RE 4runner. Took me a long time and many headaches. The clutch catches about about 1/2 way or 3/4 way up and doesn't seem to slip. In 3rd if I let it out it stalls. I've probably driven it about 30 miles so far and there is often this burning clutch smell. Is there something to adjust. I did screw up and not mark the flywheel/pressure plate when I took it off, so I just put the new one on not knowing how to line it up. Didn't seem like a big deal to me. Is this just the new clutch getting broken in? I did have my flywheel resurfaced and it was pretty rough and the clutch is an Autozone (Valeo). Any help appreciated.
Old 06-28-2009, 06:49 PM
iamsuperbleeder's Avatar
more than likely just breaking in
you did clean the pressure surfaces good with some brake cleaner right? the new pressure plate is often coated with an anti-rust agent like new brake rotors, and I've known many machine shops that'll do the same when they resurface a flywheel
Old 06-28-2009, 06:51 PM
myyota's Avatar
I would say the smell is normal, the clutch need to break in a little, like seat it self to the fly wheel, if that makes sense.
Old 06-29-2009, 06:19 PM
tesh's Avatar
hmm i'm in a similar boat - i just bought my rig with a recent (maybe 1k mi on it?) centerforce clutch and when i mash it going uphill in 3rd/4th, i get this ridiulous burning smell till i let up; it basically does it at higher rpms ... i was almost thinking exhaust leak, but it doesnt smell like gasoline, more like oil...
old87yota
10-25-2015 02:15 PM
Regency
09-06-2015 05:47 PM
Squigglez
09-04-2015 07:33 AM
Nick Berg
09-03-2015 04:36 AM
ManzDaKlown24
08-22-2015 10:25 PM
Quick Reply: New Clutch & Burning smell - help
