Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (3)
New 4runner making horrible screeching noise
#2 (permalink) |
Personal
Sales Rating: (0)
What does the oil look like?
I'd make sure you have decent oil pressure so you don't do more damage. It kind a sounds like the starter is not disengaging.
__________________
86 4Runner rebuilt 22RE Auto engnbldr kit 0.020 over, denso iridium 5305s, 10.5 x 31 dueler A/T, smitttybuilt front, custom back, RP 10w30, mech oil pressure gauge, alarm, big 3 upgrade, third brake light mod, Galant power antenna swap, starter relay mod, planet audio/pioneer 6 x 9s, Zuk rear spring mod 14 x 125 lb. Tranny Cooler, Equus Tach |
#3 (permalink) |
Personal
Sales Rating: (0)
If you are lucky, it will be the timing belt pulley.
I haven't heard what a bad one sounds like but it's been described as "screeching" before |
#4 (permalink) |
Personal
Sales Rating: (0)
Go get a cheap stethoscope (with a long rod) or even a screwdriver and start listening to various points on the head and block near your bearings. Could be nearly anything. Water pump? How many miles?
__________________
-Black 99 Runner 4x4 SR5@218k, sport hood, stock 5VZ-FE, ISR mod, 4" deck plate, stock auto 4 speed, milkshake mod(B&M 70264), inline trans filter, stock rear E -lock, differential breather mod(rear), p265/70 XLT's on stock 16's, Kenwood DNX 6960 w/ GPS, Cobra 19 Ultra, Weathertech floormats, custom roof rack(Lights&mount pending) LED reverse/cargo/dome/map(dash pending) Build thread here--->http://www.yotatech.com/f200/afartin...thread-267087/ |
#5 (permalink) |
Personal
Sales Rating: (0)
Sounds like a dry idler pulley, maybe the fan clutch. Fan has some parts missing too, those are chips missing and not just black mucking bits ya?
Not recalling the belt layout, take em off one at a time and leave the one for the fan for last, don't run for very long w/o a fan !! Start with the PS belt, that has a sealer bearing idler puller IIRC on the bottom. There is a gravely clicking sound along with the grinding squeel, seemd to be coming from the Alternator, that's bearing and brush noise maybe. hillbilly stethoscope, 2-3ft long 1x2 or random stick. Place one end on the part, put your thumb over the other end and listen thru your thumb and the cartilage thing at the front of your ear opening I prefer the stick, means I don't have to stick my head or hand near anything thats going to bite.
__________________
#6 (permalink) |
Personal
Sales Rating: (0)
PS if it was something inside the engine making that noise like the rods you'd be overheating really fast.
__________________
#7 (permalink) |
Personal
Sales Rating: (3)
[OP]
After a while of running the sound goes away. I havent Been able to pin point the noise but it sounds like it is coming from the intake manifold. I pulled the spark plugs and all three plugs on the passenger side were covered in oil. #6 cylinder on the driver side was caked in oil as well. My question now is when i check each cylinder for compression how do i determine whether the low compression i believe i will see is due to bad rings or bad valve guides?
#8 (permalink) | |
Personal
Sales Rating: (3)
[OP]
Quote:
The oil is dark and a little low. When i run the truck the oil gauge is at L so im guessing i have low oil pressure. What can cause low oil pressure? Also when i start the truck sometimes it wont ignite, im guessing this is due to the oil soaked plugs. But you can hear the starter keep spinning and winding down til it stops. If i try to start the truck again before the winding noise goes away i get a gear grinding noise |
#9 (permalink) |
Personal
Sales Rating: (0)
I am at work so I can't watch the video so this is kind if a shot in the dark. A freind of mine had a 3.0 with a squeeling that was horrible like you describe and we could not nail it down but he ordered some other parts while he was trying to fix it. His cat was original and when he put the new one on and started the truck the squeel was gone. Not much help I know but maybe seperate the front of the cat from the exhaust and check?
| Tags |
| 2002, 4runner, 93, clutch, fan, grinding, making, noise, noises, rear, runner, screeching, sequia, sound, tire, toyota |
