New 22RE swap. NO POWER!
Old 11-06-2012, 03:43 PM
DirtyHarry460's Avatar
Hey guys! iv searched around and not found what im looking for. I just finished my 22re swap. Everything in the motor is new. The only thing i swaped was the motor. Everything else stayed from my old 22re. I also changed my tranny fluid. Fresh oil in the motor. I got an oil pressure sensor from the junkyard and it gives me a very low reading. Although my oil pump is spraying up in to the valves. It idles perfectly, maybe a little high but i have the idle screw all the way down. Tonight was my second time taking it on the road. With the pedal to the floor it barley accelerates. No power band at all.
Also i have a 5 speed tranny. 4runner. 1988. Aftermarket headers. Some holes in the exhaust before muffler havnt had a chance to patch yet.
Thanks for any input!
Old 11-06-2012, 03:45 PM
Just to clarify im looking for an answer as to why i have no power.
Old 11-06-2012, 04:15 PM
rattlewagon's Avatar
Did you do any work to the motor before it was in?
Have you checked your TPS? AFM? Timing? compression?
Old 11-06-2012, 04:17 PM
waskillywabbit's Avatar
I bet timing is off.
:wabbit2:
Old 11-06-2012, 04:20 PM
HighLux's Avatar
Agree with wabbit
Old 11-06-2012, 04:44 PM
I just had the timing checked by my local mechanic. I prepped the motor as instructed, oiled the cylinders etc.
i will check afm and tps
Will i not have good compression if my rings arnt set yet?
Old 11-06-2012, 09:49 PM
wyoming9's Avatar
Red face
Explain no power a little better??
The rpm does not get over say 2000 rpm.
the speed won`t get above say 30mph on a 5 mile stretch.
You put a fresh rebuilt engine in?? As your statement every thing in the motor is new!!
if this is not the case what is the history on this engine??
Clutch slipping???
Fuel filter issues .
Your mechanic was clueless setting the timing??
Vacuum hoses on wrong
distributor off some.
Could be a whole bunch of things
Old 11-07-2012, 02:50 AM
Correct everything in motor is new. The rpms will go to rev limiter. I can get up to a good speed on the flat just takes a while. But there is no power band. If I put it to the floor it still accelerates as if I was slightly on the gas. This weekend I will have time to look into it more.
Thanks for all the input!
Old 11-07-2012, 10:56 AM
snobdds's Avatar
Your ignition timing is off.
Old 11-07-2012, 11:02 AM
Im not sure what that means... is it different then your regular timing?
Old 11-07-2012, 11:06 AM
junkyardog05's Avatar
Have you checked to see if your gas pedal arm is bent? Buddy of mine had a similar problem his pedal was somehow bent.
Old 11-07-2012, 12:00 PM
thedrewski86's Avatar
Timing is probably to blame. Look up Frieburger's (spelling?) youtube video on setting timing and get a light if you don't have one. Try searching "hot rod tv timing" or something to that effect.
I think junkyardog is onto something though, you could very well have something bent or your cable/linkage is simply not letting you gas it. I would check the SUPER simple stuff before the regular simple stuff.
EDIT: here's the link to the video. Timing is super easy but if you've never done it you have no idea what anyone is talking about!
Old 11-07-2012, 12:40 PM
Thanks a lot! I dont have time to check it out until this weekend but ill keep everyone posted, Thanks for the input!
Flying91
45
04-11-2024 04:39 PM
coleypull15
11-03-2015 07:41 AM
tj884Rdlx
08-28-2015 12:04 PM
Jeffreynmandy
07-18-2015 08:26 AM
mlavery85
07-12-2015 10:33 AM
Quick Reply: New 22RE swap. NO POWER!
