New 22RE rebuild, crank no start.
Old 07-12-2016, 03:06 PM
Iceman4193's Avatar
Hey everyone.
So I just finished my first rebuild of my 22RE and hooked it all up. It is on a 1994 Pickup.
As of now I have 2 issues.
First, the oil pressure light will not go out. I have castrol conventional 10W30 in it and I prefilled the oil filter. The oil pressure light sensor is new and when I ground the cable, the light goes out. So either I am not building pressure, or the sensor is not working.
Second, I am having a crank no start situation. Engine spins fine, I have spark, new fuel, and compression, yet no start. I have the timing set right at 5* BTDC on cylinder one, so I am not sure what else it could be.
I took a video explaining a little and giving a general look at the engine here,
I also have a thread with pretty much the whole build on it here, https://www.yotatech.com/forums/f199...lcomed-294343/
If you all have any advice on where to start looking, let me know!
Thanks.
Old 07-12-2016, 06:17 PM
Flash319's Avatar
Dump some fuel into the throttle body, put the pipe back on ans see if you get any action. Check fuel pump/pressure, Cor relay pulling in, injectors firing.......
Is your oil pressure switch in the right hole in the block?
Old 07-12-2016, 06:21 PM
91bluerunner's Avatar
For the oil pressure, I would hook up a manual gauge to where the pressure sensor is. It may just be that without the engine running, it's not enough pressure to trigger the light to go out.
As far as the no start, this may be silly but is the fuel system primed? As in there is fuel getting to the engine? From there I would recheck timing, spark and all grounds.
Old 07-12-2016, 07:51 PM
fierohink's Avatar
Do you have your afm hooked up? Without its signal the fuel pump doesn't energize.
Old 07-15-2016, 10:48 AM
Iceman4193's Avatar
Thanks for the replies guys.
Ok so I tried some starting fluid into the TB, got nothing.
What is the Cor relay?
Does anyone know what kind of oil pressure tester I need for this?
I believe there is fuel getting to the engine because I had a banjo bolt after the filter not torqued and it shot fuel all over so it should be flowing. The pressure it is flowing at, I am not sure however.
The afm is plugged in but I will reseat it to try.
My suspicion is it is not enough fuel pressure. I have refurbished injectors that may require a little more pressure than the old fuel pump is putting out.
Old 07-15-2016, 12:45 PM
fierohink's Avatar
You also have to push the door open on the afm with a screwdriver or something.
Old 07-15-2016, 05:38 PM
May be that the injectors aren't firing at all. Check that they're getting power with a noid light set. They're decently cheap sets.
They look like this:
Old 07-17-2016, 09:32 AM
Iceman4193's Avatar
While it is being started or just move the door a little with the key on the ON position?
Old 07-17-2016, 03:34 PM
fierohink's Avatar
Prop the door open while cranking. The AFM needs to be fooled into thinking air is moving passed it.
Old 07-31-2016, 06:03 AM
Iceman4193's Avatar
Ok guys,
So I finally got a chance to try some more on this thing. I tested the fuel pressure at the cold start injector and it is at 38 psi which is within range. I tried to crank it for a bit, but the battery ended up dying. I then decided to try and test the fuel injectors for resistance, even though they where sent out to RC injection and bench tested and refurbished. I noticed that they are actually outside of the accepted resistance range landing around 20 ohms compared to the accepted 13.7 - 14.2 ohms in the manual.
Could this be my problem? The injectors where all tested to work by them, so I have no idea how they are outside of the accepted ohm range.
Other than that I am still at a loss. It seems like everything is working correctly. I did try propping open the AFM door a little when cranking too but no luck.
Old 07-31-2016, 06:37 AM
I gotta say again, check that the injectors are getting a signal with the noid light set. That will give you a good lead on which way to go with your diagnosis next.
Old 07-31-2016, 12:50 PM
Iceman4193's Avatar
Those test signal to the injectors not the injectors themselves correct?
Old 07-31-2016, 01:06 PM
Yes. It plugs into the harness and shows the signal to the injector via a flashing bulb. But that will at least tell you if the issue is in the harness or injectors themselves.
Old 08-27-2016, 07:27 PM
Iceman4193's Avatar
I got it started! Turns out my timing was off TDC Exhaust... Opps.
So I am starting to break it in.
Everything seems good, however I do notice a slight clack when dropping RPMs quickly. I have a video of it here.
Is this normal during break in or does it need attention?
https://www.youtube.com/watch?v=eejsFJQ1_SU&feature=youtu.be
Also, at the end I look at one of the VSV for the AC idle up. It sounds like it it leaking a little through the top. Is it normal to have some sound coming from it?
ShadowTek
10-10-2016 05:53 AM
rustypigeon
07-13-2016 12:18 AM
Grego92
02-06-2016 12:10 PM
IMCOLOR
01-31-2016 04:51 PM
Quick Reply: New 22RE rebuild, crank no start.
