Need some wisdom
Old 08-05-2008, 01:50 AM
LittleSilver113's Avatar
Need some wisdom
Hey guys I have a 92 std cab pu. I also have a mild 302 that I want to put in it. Realistically its probably 260 to 275 horse. Im using a fresh r150 from the v6 with a 4 cylinder tcase. Should be good there as Im not too much of a wheeler here. The 4 banger just doesnt like a bike trailer. Anyone have any ideas as to what to do for the front suspension? I have SDORI BJ spacers on there but what kind of torsion bars will hold up to the added weight of the 302? Or should I pony up for aluminum heads
Old 08-05-2008, 07:52 AM
toyminator2000's Avatar
v6 Torsion bars a bit thicker and can hold more weight. Downey makes a heavy dutry set too.
Old 08-05-2008, 08:55 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
X2....
Run a forum search on HD torsion bars and you'll turn up a lot of info.
Old 08-05-2008, 09:16 AM
Jay351's Avatar
You might want to run a v6 rear third member aswell. A bit stronger then the 4cyl unit.
Old 08-05-2008, 09:44 AM
Alex 400's Avatar
and a more complete oil lubrication system. try and find them. they are good units.
Old 08-05-2008, 01:15 PM
alright ill check out the downy torsions. V6 third member huh? It that just a swap of thirds or is the housing different too?
Old 08-05-2008, 01:48 PM
Alex 400's Avatar
just the thirds are different. you can put a v6 third in a truck that came with a 4cyl third and vice-versa. (as far as i know)
Yeah the downey torsion bars are 26mm, the OME are 23.8mm (I think) and the stock bars are 22.? mm. So for a v-8 at least the OME or the downey.
Old 08-05-2008, 01:52 PM
T-1000's Avatar
Nah forget torsion bars get a coilover set up. Haha...Only a couple of grand.
Old 08-05-2008, 02:03 PM
Alex 400's Avatar
mmmmmmmmmmmmmm.....coilovers.......
Blamalam
03-12-2022 07:34 AM
mtrdrms
09-26-2015 07:12 AM
JamesDINAN
09-22-2015 05:37 AM
Quick Reply: Need some wisdom
