need some input
need some input
So I'm finally gonna replace my 22re cam with a engnbld 268, and throw on a header but I'm kinda lost at the cat and muffler. Live in mississippi so no emissions laws. So I'm thinking no cat and maybe a thrush turbo exhaust. This is setup will bring some pep back to my 86 1stgen?
I'm convinced any investments in performance gains on this motor are a waste. I saw ZERO improvement after adding a 261C cam and 2 1/4 inch exhaust. Save your money and keep it stock. If you look at the numbers between the stock cam and the ENGNBLDR cams there's only a very small difference.
Thing is you can put as much money as a 3.4 swap into the head of a 22REC engine and still be at least more then 50 horse power from the stock 3.4.
Then if you want to build your 2.4 just get the whole new head with the over size valves the cam all ready ported and polished .
The 4 into header into a 2.25 exhaust with free flowing muffler .
That will give you about all your going to get on a normally aspirated engine
Then you're looking at forced induction or an engine swap. You just are not going to get much more power out of that motor without some serious modifications.
83yotastockR
11
11-10-2015 06:54 AM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
