need some help with auto trans swap
Old 03-21-2010, 09:30 AM
ToyoTech559's Avatar
Question need some help with auto trans swap
my friend has a 92 4 runner v6 automatic 4x4. he recently swapped a 94 4 runner v6 automatic trans 4x4 into his 92. now he is having issues. the neutral safety switch is different. the 94 trans has 9 wires while the 92 only had 7.
does anyone know if the automatic trans from a 94 is the same as a 92?
Old 03-21-2010, 09:20 PM
guess no one knows lol
Old 03-22-2010, 12:36 AM
Staff
DeathCougar's Avatar
Why not just swap the Neutral safety switch?
Btw, I have swapped them before and the only difference I could find was a sensor inside the transfer case on the 94 setup. If you swap the tcase valve body, and the safety switch, you will be good to go.
Old 03-23-2010, 06:11 PM
because somehow he fried the connector and sensor
Old 04-03-2010, 04:28 PM
calipatient's Avatar
toyo: i have a 94 auto that i burn the trans on. swapped it with a auto from a 91, come to find out they are different. a trans tech told me if the neutral safety switch is diff you cant just switch them. the wiring is different and the ecu and harness would also have to be switched. so it forced me to do the manual swap (will be done when i get a day free to do it) hope that helps your question.
I believe from the research i did i found out the A340H 89-93 is different from A340H 94-95. hope this helps.
Old 04-04-2010, 06:39 AM
sweet thanks for the awesome info. i did not know this. thanks again
keithporter83
07-24-2015 07:37 AM
tobylab
Diesel Swaps
07-17-2015 06:51 PM
andrewtexas123
07-14-2015 04:29 AM
KBar
07-13-2015 06:01 PM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: need some help with auto trans swap
