Need some advice, please!!
I recently purchased and installed a remanufactured 22re with a brand new head and gasket into my 93 4wd Toyota pickup and after only 10-15 minutes of testing it down the street we parked it and called it a night due to a injector leak, and when we returned the oil was milky!!! I replaced the engine for that reason in the first place, we checked the head bolts and they are torqued to specification and my timing cover didn't seem to be rubbed by the chain or anything, but if we try to fill the radiator it just seems to flow down to the oil pan rather quickly!! At a point where we don't know what to do, has anyone experienced this? Or have some advice please just want to get my yota back on the road!! Thankyou
We torqued to 58 like the book said! We reused the timing cover,oil pan, valve cover, and intake, new head, new water pump, it came with a gasket set for everything, we've put a lot of days into it so I'm hoping there will be a fix without removing it again it's my daily driver
Staff
Reusing the EGR would not cause your problems. Toyota did later update the torque from 58 pounds to 65. Run a compression check and see what your numbers give you. Even if your intake had a crack in it, the water would go to the pistons as far as I could see. Not sure how it would get to the oil passages. Since it is the same symptoms as your last motor, I would give your intake a close look. Couldn't hurt to re inspect your other covers or parts you used for cracks.
ashamsuddin
17
01-13-2023 03:17 AM
hiluxinargentina
09-30-2015 11:12 PM
charlie_fong
09-27-2015 10:06 PM
