Need quick advice
Old 11-04-2009, 05:50 AM
4runner newb's Avatar
Exclamation Need quick advice
Wow so anyway Ive been working on my brakes for like 2 days now HAHAHA long story...
Anyway, the caliper's pistons wont push all the way back in so I cant get my caliper with the new brakes pads on the rotor...
I c-clamped the crap out of it and its not looking good im guessing new calipers is my cure?
edit 93 4runner, 4wd, 6cyl
Old 11-04-2009, 06:43 AM
Zinek's Avatar
Absolutelly, you can pick up some rebuilt units, they are not that expensive, just shop around. Even if you get lucky and force the pistons in . Eventually they will start to stick on you and your pads will overheat and will pull to either side, believe me, been there. Replace both so you save a headache later.
Old 11-04-2009, 07:25 AM
Magnusian's Avatar
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
Yes, definitely do both at the same time. When I got my truck the passenger side caliper was "fine" and the driver's side one was completely seized so I only replaced the one. Two weeks later, I was replacing the passenger side one because it ended up seizing as well.
Old 11-04-2009, 07:26 AM
User Requested Ban
theAuthority's Avatar
Yes <- quick advice
Longbed 90
03-11-2019 12:38 PM
wberry85
04-06-2018 08:45 AM
ac7822
09-12-2015 06:57 PM
DiggnDeep
09-03-2015 02:45 PM
Quick Reply: Need quick advice
