need a part name/number
I have a hose fitting and need a name or number for it.
It sits under the throttle body and is the return coolant hose...it goes back into the water pump. Its a screw in fitting with a 90° hose fitting. Mine has corroded/rusted and got a pin hole in it and spews.
Can't find one anywhere local, so it looks like I will have to go to Toyota to get one
94 22 re...its a horseshoe shaped hose. The fitting screws underneath the throttle body/intake area and horsheshoes back around to the water pump or timing cover..can't tell cause its all very tight there and under a lot of mess. I have the fitting off and have searched a few hours and can't find a pic or name anywhere and can't find anything in my Haynes manual either. Its a 1/2" coolant bypass hose
A picture sure would help.
Could it be a 90407-53007?
http://www.toyotapartsoverstock.com/...rimLevel=18290
FS[GreatLakes]: 22RE performance and stock parts (pic heavy)
05-20-2016 10:27 AM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
