need more power out of my 22 re
I have a 94 Toyota pick up with a 31s running 22 re it has a electric fan I have a intake a throttle body spacer I've done the exhaust headered high flow muffler its cammed is the next step injectors or what any advise would be great everything is lcenginering I have on it
You might be able to squeeze a bit more power out of it by advancing the timing a few degrees. You'll probably need to use premium gas and have a functional EGR so it won't ping. I run 3 degrees advanced from specs, that's the limit for passing the smog check in California.
delmert
09-30-2015 04:34 PM
