Need links for panel removal
Old 01-18-2016, 06:46 AM
Rapidrob's Avatar
I'm not having much luck with the search engine finding info on removing the AC slider panel removal. '93 Truck with AC.
I need to know how to remove the flat knobs off of the levers?
How to remove the plastic panel after the knobs are off?
Thank you.
Old 01-18-2016, 07:06 AM
scope103's Avatar
The knobs pull straight off; friction fit.
The panel is a click-fit, so just get a tool in one of the slots and pull carefully.
With all things rubber and plastic, they get brittle with age. Warming things up GREATLY reduces your risk of an accident. Wait for a warm day, use a hair dryer, or a heat gun (a heat gun can melt stuff; put your hand on the part you're warming. If too hot for your fingers, back off).
Old 01-18-2016, 07:15 AM
tj884Rdlx's Avatar
Always a good idea to mist older plastic bits with armor-all before prying. Kinda like penetrating oil for old bolts. Little extra lube goes a long way...
Old 01-18-2016, 11:03 AM
Rapidrob's Avatar
Thank you for the info. I'll warm it up and give it a try.
Old 01-18-2016, 12:34 PM
Rapidrob's Avatar
Everything came off without too much trouble. I warmed the panel with a heat gun and all but the dead center,at 6 o'clock latch came right out. That last one kicked my butt for 20 minutes until I could free it and not brake it off.
I have other questions I will post in topics.
Thanks again.
erock13
03-20-2016 08:36 PM
TURBOrunnerNM
01-13-2016 09:23 AM
LoflandJ
01-13-2016 06:35 AM
bmayer497
01-09-2016 06:45 PM
Yotapower01
12-29-2015 01:58 AM
Quick Reply: Need links for panel removal
