need help ruuush with oil gauge
Recently i swap to my 88 pickup a new sr5 cluster, today i change the original light to new one for gauge, all time the cable was disconected of light sensor ok. Issue its today i change work fine but in middle to my work travel the gauge down, not reading what happen here?
1 Post
Let me try to make sense of this....
You swapped your cluster out with a new one that had an oil pressure gauge instead of just a light, yeah?
It was working fine, then just up and quit, yeah?
Did the gauge slowly go to zero or was it like it instantly lost power and went to zero?
Check all fuses and connections.
I'm told (on this site) that using the old oil pressure switch (for the oil pressure light) with the gauge will damage the gauge. You have to change the switch for a sensor before you apply power.
Yep, i swaped and change the light sensor,for new gauge sensor, gauge work great, but in any moment loose pressure, to cero
I need clarify something, ok when connected the gauge wire to new gauge sensor and switch the key, the oil gauge up to 3/4, not supose gauge take pressure or up when engine its on?
When you turn the key to "on," the oil pressure gauge should read zero (because there is no oil pressure when the engine is not running). When you start the engine, the gauge should rise smoothly to somewhere near 1/2 way.
Im sorry my english it very bad, i try.
No only make this when wad connected the firt time, after 10 min go down with engine on, aftet this no up no down i think gauge was fry
If it worked fine and then suddenly quit I would recheck all the work you did. Double check to make sure there are no loose/damaged connections, connections that came off, or any damaged wires. Was the sensor you put on new or used? If used I would consider it suspect. I would also verify it is the correct one. There is probably a way to cause the gauge to peg out both ways to verify its operation. Some of the other guys may know how.
the1998sr5
15
07-14-2020 08:35 PM
88yodabasket
07-13-2015 01:32 PM
