Need help removing clutch pedal assembly
Old 10-05-2007, 07:59 AM
jerbear's Avatar
Hi
I have a mushy clutch pedal and after checking here first (Thanks to all who have gone before me) I find that I have a crack in the clutch/brake pedal assembly bracket. I am having trouble removing it though. Here is what I have done so far.
Remove lower dash panel
Remove electrical connections to brake switch and clutch switch
Removed 4 nuts retaining master cylinder to fire wall
Removed 1 bolt through bracket to firewall
Removed to bolts from bracket assembly to above safety bar
Removed all springs, clevis pins to both pedals.
Thing wont budge
Am I missing something?
Thanks in advance
I searched clutch pedal assembly and clutch pedal removal and did not find a thread with specific removal instructions.
Sorry if I missed it
Please point me in the right direction.
Thanks
Old 10-05-2007, 08:11 AM
jerbear's Avatar
Hi
I think I got it! Two nuts on firewall holding clutch master cylinder. I didn't realize the bolts were part of the bracket. I'll be back if I still have a problem.
09-04-2015 09:27 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
crashburnoveride
07-10-2015 06:39 AM
Kalihi,HI
07-09-2015 04:29 PM
Quick Reply: Need help removing clutch pedal assembly
