need help on rebuilding 22re
Old 12-12-2012, 09:54 PM
rockfiend's Avatar
seeing if ne one can help me identifying a problem.
i just got the head off n was checkin things out wen i notice that piston 1 moves before piston 4 does at tdc. was seeing if ne one ever had this problem. wen the rod goes side to side piston 1 moves slightly up n down but piston 4 doesnt. is the rod too long? or the crank bad or bearing out of round? i never seen this before, if ne one can help me narrow down this problem i'd appreciate it...
also this is my first rebuild
Old 12-13-2012, 06:57 AM
Hurakane's Avatar
Your gonna try and rebuild that 22re? you checked the the crankshaft? or maybe the piston rod itself might be bent,broke etc?
Old 12-13-2012, 09:01 AM
rockfiend's Avatar
i have 2 long blocks but the other one is seized up and the block has been resurface too far that it needs a shim. i havent measured the crank or rods.(dont have the tools). but ill try that first.
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
coleypull15
11-03-2015 07:41 AM
shisha1999
09-21-2015 08:22 PM
shadowbirdie
07-21-2015 10:38 PM
Quick Reply: need help on rebuilding 22re
