Need Help From People Running Ct26 Turbos
So I've Got Got My Turbo Motor All Back Together And Ready To Go In This Weekend. The Only Snag Is Going To Be Exhaust. How Do You Find The Flange That Mates Up To The Ct26 Turbo. I'm Thinking About Just Buying A Supra Full Down Pipe And Cutting Off The Flange And Building The Exhaust From There. I Just Wanted To How Everyone Else Did Theres. Thanks
A supra flange is a good idea, cut and weld.
You could call a few places that service/rebuild turbos and see if they can provide you with a weldable flange.. I didn't see any online, but they have to be available. Another good source would be the supra forums - those guys will know in 1/2 second.
Generally turbo flanges are pretty easy to make. Worst case, if you can trace the pattern, your local fab shop should be able to make one out of 1/4" steel.
You could also contact these guys - I'll bet they have 'em or can get 'em:
http://www.rabidchimp.com/index1.html
Make sure you specify supra, it's different than the ct26 from the MR2.
I got a flange for my CT26 for my 7mgte from BIC Performance. It's made of mild steel. Is this what your looking for? (its towards the bottom of the page)
http://www.bicperformance.com/products.htm
Thanks Guys For The Help. I Think I'm Going To Try And Get A Flange
And Bring It Out 3 Or 4 Inches And Stick A 2.5" Clamp. Hopefully That Will Work Thanks
the1998sr5
15
07-14-2020 08:35 PM
XtraCab
04-12-2020 05:25 AM
jasonty
41
12-23-2018 01:00 PM
